Turbocharged 318
Old Jun 30, 2009 | 01:23 AM
4x4bills's Avatar
4x4bills
Default Turbocharged 318
Hey all new to here and just want to say the place is great, I've browsed alot of the threads and have learned alot!
So I have two t25 turbos that I got cheap from a friend who doesn't use them since he upgraded to something bigger, and I'm wondering what would be a safe psi level to run them at so I don't blow anything? I know the safest route is to replace pistons and stuff with forged but seeing as they generally start at 600+ dollors... that will probably have to wait.
If it turns out this isn't a good idea and to wait and rebuild my engine that's cool but if it can work that would be awesome.
I have a Stock 318 Magnum with dual flowmaster 50 series and a AIRAID Cold air intake.
I'm relatively new to turbo's and any advice would be appreciated!
Truck: 1996 Dodge Ram Quad Cab, 318 Magnum, 4x4, Flowmaster Exhaust, AIRAID Intake.
Old Jun 30, 2009 | 01:28 AM
jasonw's Avatar
jasonw
Site Moderator
I would wait until you can get the forged stuff. And don't forget to replace the blown plenum gasket, which blows 99% of the time on these trucks.
Hughes Engines has a fix for the plenum gasket, that solves the whole problem rather than just replacing the gasket which will just blow again later down the road.
Old Jun 30, 2009 | 01:36 AM
4x4bills's Avatar
4x4bills
Thanks for the info.
I know I have to replace the pistons with forged so what else would I have to replace also to be safe?
Old Jun 30, 2009 | 01:42 AM
jasonw's Avatar
jasonw
Site Moderator
I am by no means an expert on the internals, I will let other more experienced forum members answer that question more completely.
I would just make sure that the engine is running 100%, including fixing the plenum gasket, before messing with anything like forged components or turbos.
Old Jun 30, 2009 | 01:48 AM
4x4bills's Avatar
4x4bills
Ok thanks for the help!
Just so others know I just rebuilt the tranny and also on the clutch replaced the disc, pressure plate, and throwout bearing.
Haven't had the engine actually checked but will do that anyway before I installed anything just to be safe. Much cheaper to get it checked than rebuilt.
Overall it's in pretty good condition never had any major problems with it
Old Jun 30, 2009 | 03:13 AM
helms's Avatar
helms
threre are a few different ways to approach a turbo build. one way is the redneck way. just build some turbo exhaust manifolds, bolt on the turbos, run a tube from the turbine to the intake and throw a blowoff valve in the middle. this way is VERY hick, and there is a slim chance the engine will run proper, if at all.
the proper way can get complex and expensive. i suggest first reading "the turbo bible" (http://www.turbomustangs.com/turbotech/main.htm). after you get a basic understanding of how these sytems work, you will be able to make a more educated decision.
Old Jun 30, 2009 | 01:03 PM
dakotas ram's Avatar
dakotas ram
theres a vid on youtube of a turbo'd 2nd gen that spills its guts
Old Jun 30, 2009 | 01:10 PM
dakotas ram
check out the other vids too
http://www.youtube.com/watch?v=D8sZK...eature=related
Old Jun 30, 2009 | 01:39 PM
dodgeram2001's Avatar
dodgeram2001
i just watched this video the other day Lol , Not to good .
Old Jun 30, 2009 | 02:31 PM
4x4bills's Avatar
4x4bills
Just read through that article, very informative thanks helms.
I also have the book Maximum boost, by corky bell(I think that's the author) working my way through that.
So at the minimum I'm looking at is forged pistons and a better roller camshaft? Also mod the plenum gasket. What else should I do? Don't want what happened to the guy in the vid I only have one truck!
I work in a machine shop so I have access to everything I need to make all the turbo components I need.
Thanks for the help, it's appreciated
