limited-slip differentials Additive Friction Modifier
Old Jun 30, 2009 | 01:34 PM
omanalansan's Avatar
omanalansan
Default limited-slip differentials Additive Friction Modifier
Anyone use any of this stuff? Someone just told me to put it in to see if the humming goes away in both differentials
http://www.dieselfiltersonline.com/X...fier-Xl-3.aspx
Old Jun 30, 2009 | 01:48 PM
Miami_Son's Avatar
Miami_Son
If you have a LSD you must use it or it will break down eventually. It won't do anything for a standard open differential.
Old Jun 30, 2009 | 02:03 PM
omanalansan
My build sheet:
Corporate 9.25 LD Rear Axle
Anti-Spin Differential Rear Axle
Does this type of axle require the additive?
thanks
Old Jun 30, 2009 | 02:23 PM
dsertdog56's Avatar
dsertdog56
Yes, it does require anti slip additive.
Old Jun 30, 2009 | 02:25 PM
omanalansan
Thanks dsertdog56!!!! Maybe this is the reason of my serious humming
Old Jun 30, 2009 | 02:38 PM
omanalansan
Should i just get a bottle from the dealership? actually 2 bottles
Old Jun 30, 2009 | 03:08 PM
Miami_Son's Avatar
Miami_Son
You can buy the stuff at most auto parts stores in 5-8oz bottles. My Dana 70 takes 8oz. If your diff has been running too long without the additive it may already be toast. I had my Jeep axle drained/refilled at a shop and they forgot to put in the additive. My diff was toast in less than 5k miles. I sued them and got them to pay for the damage. If yours is already making noise it is probably too late. Have a mechanic drop the cover and take a look inside.
Old Jun 30, 2009 | 04:36 PM
mikey0469's Avatar
mikey0469
i used lucas oil additive. it says you can use it as lsd additive on the bottle
Old Jun 30, 2009 | 10:53 PM
ice01's Avatar
ice01
Cool +1 On the Lucas Oil
If you use straight Lucas oil say 75-90 you do not have to use any additive it is already in the Lucas oil!! Maybe a little simpler!
Old Jul 1, 2009 | 08:48 AM
aim4squirrels's Avatar
aim4squirrels
some gear oils already have a LSD additive in it. You have to read the labels to be sure.
