Setup for Hood Hinges
Old Jul 2, 2009 | 04:52 PM
Cartalk2's Avatar
Cartalk2
Default Setup for Hood Hinges
Need suggestion on how one would go about changing hood hinges and then proper alignment?
Thanks in advance
Old Jul 2, 2009 | 05:15 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Get 2 people to help you , open the hood, while they are holding it unbolt the hinge from the hood and remove, then remove the hinges. Installation is in reverse. Install the new one's in as close to the same spot as the old by looking at the paint scuffs where the hinges mount to the body and hood, and where the bolt heads have left marks. Slowly close the hood and see how it lines up and adjust the bolts accordingly
Old Jul 2, 2009 | 09:18 PM
Ram15002ndGen's Avatar
Ram15002ndGen
I'd buy that for a dollar!
Old Jul 3, 2009 | 05:32 PM
Cartalk2's Avatar
Cartalk2
Zman17 -- As you suggested that is what was done. The old paint lines worked great for alingment. Small adjustment brought hood down on rubber bumpers.
Interesting the newer hinges have a retainer/safety on the spring -- thus they cannot come loose. Sorta loud when they let go.
Thanks
