oil temp going haywire!?
Old Jul 3, 2009 | 02:27 PM
RonRacer's Avatar
RonRacer
Default oil temp going haywire!?
my oil temp gauge keeps dropping down to 0 every time i slow down below 30mph. but the second i put my foot on the gas it jumps back up to the half way mark??? do you think this could just by an electrical issuse?
Old Jul 3, 2009 | 02:30 PM
Miami_Son's Avatar
Miami_Son
You have a factory oil temp gauge? Do you mean water temp or oil pressure? If you meant oil pressure this is a common indicator that the sender is going bad.
Old Jul 3, 2009 | 02:43 PM
zman17's Avatar
zman17
Retired Moderator - RIP
And since we don't know what year, how many miles or past history of maintenance, I'll throw in the fact, that it could also be the oil pump, oil pump screen is clogged , or the bearings are worn, if this happens only after it's up to operating temp.
Old Jul 3, 2009 | 07:16 PM
Ram15002ndGen's Avatar
Ram15002ndGen
Try the cheap thing first, change the sensor and see what happens. It that doesn't help, then you have to dig deeper, and spend more money.
Old Jul 3, 2009 | 10:16 PM
RonRacer's Avatar
RonRacer
oh. my bad you guys. its a 98 1500 5.7 with 187xxx and its the oil pressure gauge. and as far as history, i just got it a month ago and only changed the oil once
Old Jul 4, 2009 | 06:09 AM
zman17's Avatar
zman17
So does it do this right off the bat or after it's good and warmed up?
Old Jul 4, 2009 | 03:00 PM
RonRacer's Avatar
RonRacer
i'd say after its warm..
Old Jul 4, 2009 | 03:02 PM
Miami_Son's Avatar
Miami_Son
Could still be the sender. Start with the simple fix first.
Old Jul 4, 2009 | 03:50 PM
sungod's Avatar
sungod
Could also be the screen on the pick up tube partially blocked. Not knowing the history, it would be money well spend to drop the pan and replace the tube and/or oil pump at the same time. It is not a big deal or very expensive. It is not uncommon for the screens to get blocked if the previous owners didn't do regular oil changes.
Old Jul 4, 2009 | 04:15 PM
zman17's Avatar
zman17
Post #3, although I do agree with changing the sending unit first. And just so you know, it's under the distributor. And you thought changing the cap was a pita,
