Check engine light code P302
Old 07-05-2009 | 04:56 PM
97r/tram's Avatar
97r/tram
Default Check engine light code P302
Hey ya'll I'm new to the site and on my 1997 dodge ram 1500 (5.9 gas) I keep getting a code of p302 cylinder 2 misfire. I've checked the cap and rotor, it looked fine, very little corrosion and no wear on the rotor. I put new 7mm bosch spark plug wires and champion platinum plugs. Compression test shows 125+ on all cylinders and I put a new Accel coil on it. I've had it on the obdII code reader at autozone 10+ times and it's always the same code. When I did the compression test, I put a new plug in the #2 cylinder and the check engine light went off immediately. That was 2 weeks ago, and yesterday the light came back on. Keep in mind that the light came back on after I put the new accel coil on it. Anybody got an idea?
Old 07-05-2009 | 07:46 PM
aim4squirrels's Avatar
aim4squirrels
might be a deflated lifter...
Old 07-06-2009 | 12:55 AM
dhvaughan's Avatar
dhvaughan
hey loganville, welcome to df.
pull plug #2 and see if its fouled. if so it might be plenum.
compression check seems good, so its not the unspeakable (cracked head).
i might replace rotor and cap just to rule it out.
did the cel go out on its own after you replaced the coil, or did you reset pcm.
how long did it stay out before coming back on ?
i read that cel also went out immediately after new plug...
and stayed out for 2 weeks and has now come back...
Old 07-06-2009 | 03:01 PM
97r/tram's Avatar
97r/tram
Last night I put in a new cap and rotor, the old one was pretty worn. I'd say 100,000 miles plus of wear, and I put a new spark plug in the #2 cylinder. The cel went immediately off, same as last time. I never had to reset the computer because as soon as I put a new plug in, the cel goes off. It was about 150 miles or so of driving when the cel came back on 2 days ago . The motor has a little lifter sound coming from it when it's cold. I used marvel mystery oil and it cleared it up, but could it still be a deflated lifter?
Old 07-06-2009 | 03:58 PM
zman17's Avatar
zman17
Retired Moderator - RIP
So what did the #2 plug look like when you pulled it? Did you check or replace the SP wires? And check the Plenum or CC ?
Old 07-06-2009 | 04:38 PM
Gary-L's Avatar
Gary-L
Check the plug wire routing.
Old 07-07-2009 | 02:42 PM
97r/tram's Avatar
97r/tram
The spark plug looked ok. It was black behind the electrode and a little carbon on the tip, but wasn't gunked up with buildup. I put spectre wire separators on all of the wires the day I put the cap and rotor on. Could the spark be arcing on the metal plug protector that goes around the spark plug boot?
Old 07-07-2009 | 09:33 PM
dhvaughan's Avatar
dhvaughan
it might on old, cracked wires, but it would not with new wires.
and if it did - you would see it at night and hear it snapping, and also see burn evidence.
did the cel come back on yet ?
Old 07-07-2009 | 10:29 PM
eaglestorm's Avatar
eaglestorm
you could have a dirty injector
Old 07-09-2009 | 01:39 PM
97r/tram's Avatar
97r/tram
I put a brand new sorensen fuel injector from autozone in the #2 spot. The cel went off after the new plug and hasn't come back on yet. The spark plug wire boot isn't burnt at all as they are new wires.
Quick Reply: Check engine light code P302
