Diff Backlash
Old Jul 10, 2009 | 11:53 AM
Thumpper369's Avatar
Thumpper369
Default Diff Backlash
I recently changed bearings in the rearend and im hearin noise. I'm pretty sure i didnt get the diff bearing preload set correct. I have a manual and it tells me what to do only thing im kinda a lil sketchy on is measuring the backlash. What tool do i need to measure this? i have a 2001 Dodge Ram 5.2L 4x4 3.55 ratio with the Trac-lok diff.
Old Jul 10, 2009 | 12:35 PM
Sawed Up's Avatar
Sawed Up
Did you add the friction modifier in with the fluid?
Old Jul 10, 2009 | 12:56 PM
Thumpper369
i got thicker lube went with the 140 but i can def tell its ring gear noise. im pretty sure i didnt set the backlash or bearings correctly the one guy said turn the adjusters back the number of turns i unturned them and i did or so i thought... so im i just have to start from scratch
Old Jul 10, 2009 | 02:17 PM
helms's Avatar
helms
you need a dial indicator to measure backlash, without it you have no idea what it is. there is no set amount of turns for the adjusters, every unit is going to be different.
Old Jul 10, 2009 | 02:22 PM
aim4squirrels's Avatar
aim4squirrels
+1 and I'll add that if you're hearing noise it might be too late for the set of gears that you have.
Old Jul 10, 2009 | 02:26 PM
97black_ram's Avatar
97black_ram
+2 on dial indicator.
Check this link for bolt torque and backlash settings.
http://dodgeram.org/tech/specs/axle/9_25specs.html
How far did you drive it while it was making that noise?
Old Jul 10, 2009 | 03:48 PM
helms's Avatar
helms
you will hear a whine if the gears are too tight or too loose, there is a happy spot in the middle that should produce little to no whine like we are used to hearing.... or not hearing, lol
