What is this part I just broke?
Old Jul 19, 2009 | 10:15 AM
97sport's Avatar
97sport
Default What is this part I just broke? PICTURE ADDED!
I was trying to track down vaccum leaks in the cruise control and removed the battery tray. I ended up wrecking the plug to an electrical part. It is rectancular in shape, with a triangular base that mounts to the fender with 3 bolts, and a 2 wire plug. It is located just below the cruise control on the drivers side of my '97. There is an identical component mounted in the same place on the passenger side.
What is it and can I live without it?
Old Jul 19, 2009 | 10:24 AM
Ram15002ndGen's Avatar
Ram15002ndGen
I have the same components on mine. Don't really know what they are, but I assume it may have something to do with the lights since they are mounted directly behind them. Try your lights and see if they work properly in all modes.
zman17's Avatar
zman17
Retired Moderator - RIP
I have a 98 and don't see what you are describing anywhere on either side. It may be different on yours, but it could be the impact sensor for your air bag(s) I suppose. So you may not be able to live without it.
Old Jul 19, 2009 | 10:40 AM
Sheriff420's Avatar
Sheriff420
do you have a camera? a picture sure would help.
Old Jul 19, 2009 | 10:47 AM
97sport's Avatar
97sport
Charging the camera now, will get a pic posted in a bit.
Old Jul 19, 2009 | 11:01 AM
zman17's Avatar
zman17
I was going to suggest the camera thing also but forgot, sorry, good call Sheriff, I think it will take a pre 98 owner to ID it right off the bat or a little research. BUT, I think I'm right.
Old Jul 19, 2009 | 11:07 AM
97sport's Avatar
97sport
This is a picture of the component mounted on the passenger side fender, near the front clip.
Attached Thumbnails What is this part I just broke?-fishingtripapril09-014.jpg
Old Jul 19, 2009 | 12:23 PM
Sheriff420's Avatar
Sheriff420
yep, i don't know. thats where my horn is at. you need to get laramie to chime in.
Old Jul 19, 2009 | 12:28 PM
zman17's Avatar
zman17
I'm almost positive I'm right. Take a pic from a little farther away, so I/we can have a better perspective of where it is located.
Old Jul 19, 2009 | 12:42 PM
Miami_Son's Avatar
Miami_Son
Ditto. And try using the flash.
