01 RAM "BAFFLING"Air Conditioning Problem
Old Jul 20, 2009 | 11:35 AM
D_ram22's Avatar
D_ram22
Question 01 RAM "BAFFLING"Air Conditioning Problem
I need some help. I have trying to get my AC cold. everything I have done is listed below and at this point I am baffled. Why can't I get the cabin temp below 70 degrees?? any help would be greatly appreciated.....
AIR CONDITION SYSTEM ON 01 DODGE RAM 1500 4WD 5.2 L ENGINE
1. REPLACED EVAPORATOR CORE - CORROSION EVIDENT AT BOTTOM OF CORE
2. REPLACED COMPRESSOR - LEAK WAS EVIDENT AT BEARING SEAL
3. REPLACED DRIER
4. REPLACED FLUID LINE WITH ORIFICE TUBE
5. FLUSHED AND DRIED, EVAPORATOR CORE, CONDENSER, AND MANIFOLD HOSE ASY
6. ADDED 5oz OIL. REASSEMBLED AND REPLACED O-RINGS AS NECESSARY
7. EVACUATED THE SYSTEM TO 30 hg FOR 30 MIN. PUMP OFF AND LET SIT FOR 20 MIN. NO LEAKS
8. CHARGED SYSTEM TO 35 LOW / 205 HIGH
ABT 94 DEG
RPM GAGES CABIN CONDTEMP REMARKS
L H TEMP IN OUT
750 44 265 70.2 124 104 MOISTURE ON OUTLET OF EVAP, STOPS AT ORIFICE TUBE
1200 25 250 74 132 103 MOISTURE ON OUTLET OF EVAP, STOPS AT ORIFICE TUBE 1500 18 230 75 134 114 CYCLES AT 18 HIGH SIDE CONSTANT
ENGINE OFF AFTER TEST GAGE READING 115 LOW, 130 HIGH.
AT 1500 RPM, HOT SMELL WAS EVIDENT.
Old Jul 20, 2009 | 12:13 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Make sure the blend door is operating correctly and not letting the heat by. And just curious, but how many cans of 134A did it take?
Old Jul 20, 2009 | 01:20 PM
D_ram22's Avatar
D_ram22
just over 2. Where is the blend door??
Old Jul 20, 2009 | 01:31 PM
zman17's Avatar
zman17
Under the dash in the hvac box. Maybe you didn't put it back together right or something got broke when you changed the evap core.
Old Jul 20, 2009 | 01:41 PM
D_ram22's Avatar
D_ram22
GREAT! Is there a way I can check that out without taking the dash back out??
Old Jul 20, 2009 | 03:31 PM
zman17's Avatar
zman17
Other than moving the dial back and forth rapidly so you can hear it slam shut in both directions no. Plus IIRC there might be an electronic actuator on a 2001.as opposed to earlier models like mine with a cable.
Old Jul 20, 2009 | 03:34 PM
D_ram22's Avatar
D_ram22
Thanks, I will check that out tonight and let you know what I found.
Old Jul 20, 2009 | 04:39 PM
Kaldir's Avatar
Kaldir
When you added the fluid, did you have the AC set to max with the engine running? Also if you had the whole system drained, you might need more then 2 cans.
Old Jul 20, 2009 | 04:49 PM
pavement_hater's Avatar
pavement_hater
Most small cans are 12oz though there arer some that are bigger. The system will take 32oz (2lbs) to be correct. If you overfilled it or didn't use enough, it will not cool correctly. Overfilling could cause the compressor to lock up so be carefull with that.
Last edited by pavement_hater; Jul 20, 2009 at 04:55 PM. Reason: Note to self....learn how to spell
Old Jul 20, 2009 | 11:39 PM
D_ram22's Avatar
D_ram22
OK, Thanks for all the help. I cycled the ac controls several times through the whole range, all servos are moving and all doors ar opening and shutting. When I did the test, I had it on max, fan on high, I waited 10 min for system to stabilize. my reading are on #1 post. I played with the refrigerant, I added alittle at a time until the temp started to climb. I vented until I got the coldest temp. Is it normal for the low side pressure to drop so low at 1500 rpms? I suspect the condenser need to be replaced, that it's not cooling the refrigerant properly. I'm searching for confirmation. this is a learnig evolution for us and me. so please keep going. I'm sure we can figure this out.
