Miss/Stumble @ Idle
Old 08-06-2009, 01:43 PM
mcss8541's Avatar
mcss8541
mcss8541 is offline
Originally Posted by zman17
Cleaning the IAC is not an end all solution(it may still be bad), but you also need to check the plenum.
I agree with Zman, cleaning that thing doesn't fix it. If you really think it's that then replace it.
Old 08-18-2009, 03:08 PM
gobbell1's Avatar
gobbell1
gobbell1 is offline
OK...FINALLY FIGURED THE PROBLEM OUT AND FIXED IT!!!!!
As it turns out, the slight, erratic stumble I was getting @ idle was due to my plug wires! The stumble would occur hot/cold, full/empty tank, etc... It even started to stumble at around 45 mph. However, yesterday it went full tilt and would kick and buck and even threw a CEL.
Long story short, the CEL was P0300 thru P0308 (meaning a misfire in all 8 cylinders). NO WAY I thought, unless the wires were shot and the coil wire was messing with all of them. Lo and behold, a new set of wires did the trick.
Old 08-18-2009, 04:24 PM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
glad to hear that you got it figured out.
my old plug wires had a split on the #8 cylinder and weren't routed properly. when i did the re-route and put new wires on it made my rpm surge go away.
Quick Reply: Miss/Stumble @ Idle
