steering components
Old Jul 22, 2009 | 09:51 PM
cowboybob2001's Avatar
cowboybob2001
Default steering components
ok here we go
I have to redo my left tie rod ends as well as my pitman arm end. I decided that I'll just do everything all at once, so I bought the parts and am looking at the truck trying to figure out a procedure to do it. I cant get the truck in for a wheel alignment right away because the shop is crazy busy. I need to know if anyone has tackled this project before? what should I watch out for? and how much did it effect your steering after the fact? All the work is being done on a 01 ram 2500. any help would be appreciated
Old Jul 23, 2009 | 09:57 AM
Sheriff420's Avatar
Sheriff420
changing the tie rod is easy, about a 5-10 minute job after you get the wheel off. then you can do a driveway alignment, the diy section has instructions on how to do it.
https://dodgeforum.com/forum/2nd-gen...m-removal.html
https://dodgeforum.com/forum/dodge-c...djustment.html
one thing you can do to keep your alignment close to what it is before the swap is to measure the original from the sleeve to the end of the tie rod end and put the new one in the same spot. i think you can just unbolt the side of the sleeve that holds the tie rod end to get it off without threading the sleeve onto or off of the tie rod itself.
Old Jul 23, 2009 | 11:58 PM
cowboybob2001
hey thanks for the info. did the work tonight. took about 2 hours and the truck seems to ride the same as it did before so i think im ok untill i get it in the shop. I actually left my wheels on while I worked. I figured I might as well use them to keep everything in line. since the truck never moved it was just a matter of lining up holes. did take lots of measurments though.
Old Jul 24, 2009 | 02:59 PM
Sheriff420's Avatar
Sheriff420
that sounds like a good way to keep the alignment pretty close.
Old Jul 24, 2009 | 07:54 PM
charlie1935's Avatar
charlie1935
I always counted the number of turns it took to remove the old one and turned the new one in the same amount. Worked for me.
Haven't used any of the later ones made in China though.
