Help finding part
I found this one here:
http://www.transmissionpartsusa.com/...-000053396.htm
Is this all I need, or do I need to get some other sensor, too? Need to get it ordered ASAP. I don't like having to rap it out to 4500 rpm to shift out of 1st.
Thats the correct link for the solenoid.
http://www.transmissionpartsusa.com/...-00053397a.htm
^Thats the pressure sensor. I replaced sensor and solenoid together.
You'll also need about 6 quarts ATF+4, gasket, and might as well change the filter while youre at it.
Okay, I was wrong I think. My code was P1762, which is the Gov Pressure Sensor, not Solenoid. Manual says:
"Sensor input greater or less than calibration for 3
consecutive Neutral/Park occurrences (4-speed auto.
trans. only)."
So should I still replace both in this case? Not trying to beat a dead horse, but I don't know if these parts work hand-in-hand, and I don't want to replace one just to have the other fail on me.
trans. only)."
Okay, thanks, guys...I will order both. And, yes, I will definitely be getting a drain plug. What stinks even worse is that the day it started acting up, before it threw the code, I did a light service to see if it would help the situation. Now I have to waste about 5 qts of brand new tranny fuid.
EDIT: Got 'em both ordered from Transmission Parts USA for $110 with 3-day shipping. According to the manual, doesn't look like a very difficult job. Thanks again for the input guys!
