cross threaded oil filter
I found this on a search The guy had the same problem..
"After all the drama I went and bought a new pair of good needle nose and went home. While waiting for the friend to bring the tool he made over I decided to try once more and stuck the needle nose up in the whole and into the slots and used my breaker bar between the handles. The last piece spun right out with ease. I believe this is because the bike was cold and sitting in the shade of my garage compared to hot when it stuck. Anyway after all the drama the threads and all were perfect and the new filter spun on with ease and only got a half turn after finger tight and the bike is back on the road. Thanks everyone for the advise and in the end patience and time were the keys"
if you do the dremel route then make sure you use goggles and not just safety glasses. every time i've been to the eye doc it was because i got a piece of metal lodged in my eye from wearing glasses and grinding. and make sure you have both hands on the dremel with it on a low speed so it won't walk off the filter and rip into the block or a wire or something. if you put multiple cuts on the edge of the filter where it meets the block then it will relieve the pressure and you should be able to pry it off with a flat head pretty easy. also keep in mind that if you go too deep that you'll be throwing grinding dust into the oil ports on the block and that wouldn't be too good.
also, lets get a picture of this mangled filter on here.
