best place to run wires through the firewall
Old Jul 30, 2009 | 06:45 PM
Laramie1997's Avatar
Laramie1997
Sheriff, there must be a huge echo in this thread....
Old Jul 30, 2009 | 09:33 PM
dhvaughan's Avatar
dhvaughan
Originally Posted by Scottmilkeway
now you say just drill a hole in the grommet itself? and wheres the grommet located? could you possibly post a pic or something?
its a huge rubber grommet beside the steering column, and its where the clutch rod goes through on a manual. just poke a hole in it with your pocket knife.
here's a pic.
Old Jul 30, 2009 | 10:40 PM
Ram15002ndGen's Avatar
Ram15002ndGen
On mine it's either a hard plastic or the rubber has dried out. I drilled a hole in it for my fogs and later back filled with some clear silicone to make it water proof.
Old Jul 30, 2009 | 11:39 PM
95MaroonMonster's Avatar
95MaroonMonster
i used a grommet that was about 3 inches in diameter for the power wires for my CB
Old Jan 21, 2010 | 04:22 AM
emtpa's Avatar
emtpa
Default this rubber plug
Does any one know if this plug is on the 04 ram model. I need to run some wires for grill lights.
Old Jan 21, 2010 | 01:04 PM
011500Ram's Avatar
011500Ram
I pushed the grommet partially though, and have about half a dozen wires threaded through there. Then I sealed it back up with black silicon. Works like a charm!
Old Jan 21, 2010 | 01:07 PM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by Laramie1997
On the Driver's side, under the dash, there is a little rubber grommet that you can drill a hole through. That will give you access to the battery. It's the one that I used to run all my power wires for the amp.
ditto.....was plenty of room for my 0 guage wire for amps and other wire as well.
and you can splice into the power outlet a cig lighter or even car stereo wiring for this without cutting them?? why would you cut them?
is a very low amp draw lighting system so running to the battery is more work than needed....
Old Jan 26, 2010 | 10:29 PM
TheGreatDrake's Avatar
TheGreatDrake
+1 find you some thief taps and splice into the cigar lighter wires. I work at a communications shop and I've seen this done on literally hundreds of trucks with no problems whatsoever and the plug is still functional. you can use those wires for hands free kits, cell phone cradles, and even the remote line for your amp if your radio doesn't have one. I wouldn't advise hooking up a cb or a VHF/UHF radio to it though, it will work but you run a great risk of burning up some wires. oh and on our trucks the top one is switched ignition and the bottom one is constant.
Old Jan 27, 2010 | 11:17 AM
yakkier's Avatar
yakkier
+1 ^ same thing i did for my toggle for my foglights, just dont remember if you damage the grommet too much to seal it off with some RTV or gasket sealer so you dont get any cold air in and also keeps the inside quieter
Old Apr 30, 2010 | 12:21 AM
Bubba39047's Avatar
Bubba39047
sorry to bring up the thread. But what about if your equipt with the manual tranny? where then. I have so many wire going through the gap between the door and the hood..i need to redo em.
