msd 6a box
Old Aug 2, 2009 | 10:52 AM
Rockyhigh360's Avatar
Rockyhigh360
i get better idle and about .5 mpg better with the 6a and tach adapt hooked up.
Old Aug 2, 2009 | 10:37 PM
lastrights's Avatar
lastrights
so what gap you guys running for the best peroformance is it ok to just run it stock , and where does the tach hook up too the box or the coil or what ??
Old Aug 3, 2009 | 08:31 AM
aim4squirrels's Avatar
aim4squirrels
tach adapter plugs into the box IIRC, I'd have to go check to be sure.
I run a .045 gap and it seems to do well.
Old Aug 3, 2009 | 08:54 AM
Laramie1997's Avatar
Laramie1997
Originally Posted by aim4squirrels
Also, my 2009 definitely needed the MSD tach Adapter P/N 8910. Keeps a P0351 code from triggering in the PCM.
Not to thread jack, but does that comment mean you have already traded, or is this on the wifey's rig?
Old Aug 3, 2009 | 09:00 AM
aim4squirrels
nope, just head up my butt. I still have the 2001. My wife wouldn't be caught dead in a truck. She hates mine...
Old Aug 3, 2009 | 03:22 PM
lastrights's Avatar
lastrights
so how hard is it to install and where are you hooking up the wires at and about how long did it take to install ?? thanks thats my last questions
Old Aug 3, 2009 | 11:23 PM
Rockyhigh360
Took about an hour.... but I'm a sparky. Take the time to use male and female crimp connectors for your wires so you can disconect with ease. The tach adapt is also very simple, the msd wire diagram is easy to read. I also used some red plastic flex wire tubing to conceal the wires and about a handfull of zip-ties
Old Aug 4, 2009 | 06:13 AM
lastrights's Avatar
lastrights
thanks guys !!
Old Aug 4, 2009 | 07:40 AM
lastrights's Avatar
lastrights
http://www.summitracing.com/parts/MSD-8910/ is this the right adapter ?? there is 2 with the same part # and dont look the same and this is the box http://cgi.ebay.com/ebaymotors/MSD-6...Q5fAccessories
Old Aug 4, 2009 | 08:17 AM
Twisted Metal's Avatar
Twisted Metal
Last, double check the numbers against the ones listed on MSD's website. Or even better give them a quick call their tech support is really good. Just to throw another $.02 in, mounting location should not be overlooked. We use MSD boxes in the race cars. They are durable but not bulletproof, Take time to consider where and how its gonna be mounted. Use the rubber insolators for the mounting bolts, vibration can be the achillies heel for them.
