msd 6a box
Old Jul 31, 2009 | 09:30 PM
lastrights's Avatar
lastrights
Default msd 6a box
im going to be ordering the msd 6a box, i was wondering if anyone know where the diy for the wireing and what not, i know its on here somewhere but cant find it
Old Jul 31, 2009 | 09:38 PM
99blue360mag's Avatar
99blue360mag
https://dodgeforum.com/m_405881/tm.htm
Old Jul 31, 2009 | 10:24 PM
dodge15004x45.9's Avatar
dodge15004x45.9
It's a dam shame tht most of the older DIY's are missing there pics!
Old Aug 1, 2009 | 12:23 AM
Trey318's Avatar
Trey318
True that. Makes the DIYs a lot harder to follow.
Old Aug 1, 2009 | 09:43 AM
aim4squirrels's Avatar
aim4squirrels
Make sure you order that Accel Adapter to hook into the stock coil plug.
http://www.summitracing.com/parts/ACC-140021AH/
You definitely don't want to cut off the old plug as you can quickly swap back to the stock coil should you have an MSD coil or box failure. Cut the black part off that adapter and hook in there.
Also, my 2009 definitely needed the MSD tach Adapter P/N 8910. Keeps a P0351 code from triggering in the PCM.
If you're using one of the round blaster coil you can use some band pipe clamps from the hardware store to hold the new coil in place and keep the old coil bolted in too. Looks almost like a clevis hanger, but it was designed slightly different.
Old Aug 1, 2009 | 07:25 PM
lastrights's Avatar
lastrights
i have the msd blaqster coil already along with the accel adapter, whats the msd tach adapter for aim4squirrles?, and also what all did you notice with the box.
i already have ngk iridium plugs, msd wires coil , evreything is ready for a box, ill just need to change the cap/rotor mor often , and how many miles would you reccomend changing the cap and rotor with the box ?? thanks buddy
Old Aug 1, 2009 | 08:47 PM
lastrights's Avatar
lastrights
found this to be very interesting about msd boxes http://www.youtube.com/watch?v=uUBiuGzKGOs
Old Aug 1, 2009 | 10:26 PM
aim4squirrels
I need to change caps and rotor at 25~30K
The tach adapter does something to correct the signal from the box to the PCM so it doesn't trip a P0351 code about the coil voltage. I can't recall exactly what and why, but I know mine threw it, and Padodgeram had a post about exactly what it was since he got it too, and asked MSD about it.
Got a little boost in initial throttle response from adding the box, don't know if it does anything up top, never dynoed it.
Old Aug 2, 2009 | 06:54 AM
lastrights's Avatar
lastrights
thanks buddy , has the box ever left you stranded , on another forum i was going back on some post about the box and some people have said it letf them stranded , but luckly they were able to put it back to stock ignition, thats the only thing im afraid of
Old Aug 2, 2009 | 08:38 AM
aim4squirrels
never had a problem with mine yet.
