truck dies and trans problem
Old Aug 5, 2009 | 01:51 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Buy a manual while your there. And don't buy a POS sensor from Autozone. And btw, how does it run when you first start it in the A.M. ?
Old Aug 5, 2009 | 02:39 PM
ruquick77's Avatar
ruquick77
It runs a lot better in the morning, I wouldn't say good but once it warms up it start running worse.
Old Aug 5, 2009 | 03:23 PM
zman17's Avatar
zman17
You might want to try removing the TB and cleaning it and the IAC. Then do a search on here for plenum. Get that manual though, it will tell how to check the other sensors,like the ECT for instance. You could have a bad cat or going bad, and a blown plenum gasket. Mean while you can pull the plugs and see what they look like.
Old Aug 5, 2009 | 03:49 PM
Trey318's Avatar
Trey318
Dang zman you must be feelin your oats for postin those pics :P
Old Aug 5, 2009 | 03:54 PM
zman17's Avatar
zman17
LOL! I'm not going to be around for a while after tomorrow, so I figured I would be helpful for a change.
Old Aug 5, 2009 | 04:48 PM
Trey318's Avatar
Trey318
lol. Good luck with the surgery. Hope it goes well for ya.
Old Aug 6, 2009 | 10:43 AM
ruquick77's Avatar
ruquick77
**UPDATE**
NEW
Plugs
wires
cap
rotor
TPS
CLEANED
TB
IAC
Runs rough and has no power, the warmer it gets the worse it runs. Burned a 1/4 of fuel in 30miles. No check engine light, does come on when I turn key on. Checked for codes anyway and no codes.
Thanks for any help.
Old Aug 6, 2009 | 10:56 AM
zman17's Avatar
zman17
Unscrew the o2 sensor in front of the cat and see how it runs.
Old Aug 6, 2009 | 01:46 PM
ruquick77's Avatar
ruquick77
I unplugged the o2 sensor and it ran the same.
Old Aug 6, 2009 | 01:48 PM
zman17's Avatar
zman17
I said unscrew not unplug.
