Right front U-Joint
Old Mar 2, 2010 | 04:50 PM
Miami_Son's Avatar
Miami_Son
Just be careful not to damage the hub wiring. Otherwise, the procedure is the same.
Old Mar 3, 2010 | 08:54 AM
blktre's Avatar
blktre
Thanks Miami! I will be careful removing/installing the axle.
On a side note, is the hub nut the same size on the 2500 as it is on the 1500? The FAQ says the 1500 needs a 1-11/16" Socket, hoping its the same for the 2500!
Thanks....
Old Mar 3, 2010 | 12:46 PM
Miami_Son's Avatar
Miami_Son
Not entirely sure, haven't had to remove mine yet, but it will need a large socket. Do us a favor and fill out your profile info so we know what truck you have every time you post. Good luck.
Old Mar 3, 2010 | 01:13 PM
dodgegirl05's Avatar
dodgegirl05
i know on the 3rd gens if you replace the u-joint you have to replace the bearing as well! is that the same for the 2nd gen???
Old Mar 3, 2010 | 03:50 PM
Miami_Son's Avatar
Miami_Son
Not usually, but it depends on how hard a time you have removing the bearing assembly. You look hot. Too bad you're a NE fan.
Old Mar 3, 2010 | 07:08 PM
blktre's Avatar
blktre
Ok, I'm talking about my 98 Ram 2500 4x4 v10. Its in my profile now....
Anyways, I removed the 4 14mm flange bolts and the main hub nut. I also removed the 4 bolts that hold on the CAD vacuum motor and removed the fork from the axle. I rented a puller and have gotten some outward movement of about 1/4". I noticed the U-Joint assembly is now pushing against the back of the knuckle. So it seems im not getting very far.
Is the entire axle supposed to come like it seems is happening?
Is there a keeper somewhere that needs removed?
Am i on the right track?
Id take any comments and advice.
Thanks again,
Andy
Old Mar 3, 2010 | 07:50 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The hub bearing assembly is just stuck/rusted (the part you removed the 4 14mm bolts from) Go to a hardware store and get some bolts that are the same, and you can screw them back in and beat on them,instead of destroying the factory ones.
You should also get a Haynes manual
The bearing and axle are separate parts. The bearing will come out and then the axle.
Old Sep 23, 2012 | 07:56 AM
Jedpole's Avatar
Jedpole
Post U joint
I have to change mine today where I could pick up theU joint. Think I will try autozone.
Old Sep 23, 2012 | 08:25 AM
dhvaughan's Avatar
dhvaughan
old thread....
considering how much work it is to change a ujoint, i wouldn't put in an autozone part. get the Precision brand Super Strength. they offer greasable or non-grease and run $20-30 each. available at napa, oreilly, internet, etc.
if you get the greasable, you will need the screw in grease adapter. they don't use standard zerk due to low clearance. its about $5.
Old Sep 23, 2012 | 01:27 PM
Jedpole's Avatar
Jedpole
Originally Posted by TimSully88
If you have $45 dollars for parts, the right tools, and 3 hours, it a breeze. Just did mine last week and it was no problem even with all the rust I have. As far as the necessity...I claim to be no expert but I definitely noticed an improvement in my steering. I did both and the slight drift I had even after an alignment went away.
Which raises a good question, why didn't the god damn tire people tell me about this issue. I'm actually surprised they didn't try to get more money out of me by suggesting it.
Back to the point though...depending how badly worn they are, you run the risk of warping the "U's" if you will. I dunno the real name but the parts the the joint connects may need to be replaced if you wait. And the kicker, like in my case...you may find you need to do bearings/hubs as well. So weigh your options and bank account cuz hubs are $100 a piece minimum...
Hope this helps
Hey Tim what tools do I need to tackle this job.
