Lighting Need help!
Old Aug 16, 2009 | 12:52 AM
  #31
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by Miami_Son
The factory setup uses a relay, full current does NOT go through the switch.
The low beam relay is in the switch.
Correct me if I'm wrong, but sounds like you changed your story.
No offense man, but I'm calling B.S. If the switch has a built in relay, it wouldn't melt occasionally as has been known to happen (and happened to me).
Old Aug 16, 2009 | 01:12 PM
  #32
Miami_Son's Avatar
Miami_Son
Not at all. My original comment was that the headlight current doesn't go through the switch, meaning the actual switching component you turn on and off with your fingers. It doesn't. That switch activates a relay that just happens to be inside the switch housing. It is a stupid setup as this makes the entire switch housing prone to heat buildup from the current flowing through the relay, but my original response remains correct although technically I can see your point. Just wear a hat and no one will notice.
Old Aug 16, 2009 | 07:25 PM
  #33
fukinavit's Avatar
fukinavit
nah man, you were caught with your pants down there. some guys know more than others, no biggee, just admit you were wrong and move on.
Old Aug 16, 2009 | 09:00 PM
  #34
Miami_Son's Avatar
Miami_Son
Nope.
Old Aug 17, 2009 | 01:57 PM
  #35
RonRacer's Avatar
RonRacer
i see what mami is saying... jason where did you get your relay from?? i'm having the same issue with mines. what do you guys think about HID upgrades also?? i was searching the threads but could really find anything....
Old Aug 17, 2009 | 03:24 PM
  #36
jasonw's Avatar
jasonw
Site Moderator
I even went into the service manual and went through the wiring diagrams, but Dodge shows all the relays as switches, with the label "Horn Relay" or "A/C relay" or whatever.
Since neither of us can find proof one way or another yet, I'll call it a day on that argument. Agree to disagree.
I got my relays from Advance Auto. Standard 30A automotive relays.
HID upgrades are nice, but make sure to get 35w ones. The 55w units will be to bright and blind oncoming traffic.
These are the cheapest excellent quality ones I can find so far:
http://www.ddmtuning.com/index.php?p...=101&parent=85
Avoid eBay units if you can. Usually overpriced, or priced way to low (to good to be true), one extreme or another, and they are usually poor quality (don't ask how I know).
Old Aug 17, 2009 | 03:33 PM
  #37
Hg1's Avatar
Hg1
Default Its the Wiring harness
Hi, new guy here. The problem is with the wiring harness that came with the lights you bought. I had the same problem when I changed my headlights to a dual bulb, HID setup. Look at the photos I took:
You need to switch the Blue wire with the black wire. The way your lights came out of the box isn't wired correctly for the Ram, the ground (-12) is in the wrong position. If you switch the blue and black wire, everything will work fine.
Here are photos of the headlights I installed:
High beams / Day time running lights (Canada)
HID's Low beams, (4300K). I just turned them on so that is why they still look blueish, they are actually white like real HID's on Benz's and BMWers.
Old Aug 17, 2009 | 07:22 PM
  #38
Mowhawk's Avatar
Mowhawk
Thanks but i already made an adapter so they work. Mine said i cant use hids wit htehm. Oh well
Sick lights though.
Old Jan 10, 2010 | 06:48 PM
  #39
Digitoxin's Avatar
Digitoxin
Default headlights issue
Man, I now this thread go's back a while, but it is very informative. My girl friends headlamps are dim on high beam, and low beams are ok, and the high beam indicator lamp is always on. Found out with the help of this thread, the bulbs are the wrong ones. Had 9007 bulbs. Thanks for all the help. this forum rocks!
Old Mar 22, 2010 | 03:10 PM
  #40
Pstiles's Avatar
Pstiles
Default Projector light Problems
Hg1, what do you mean by switching out the blue and black wires? I have just installed these lights and have similar problems, such as my fogs dont come on when headlights are on, dashboard always reads hi beams on, and when I actually do turn on my high beams both low and high come on but they are dimmer than when only the low beams are on. I have a 2001 dodge ram 1500 sport.
