hey guys need an anserw
Old Aug 10, 2009 | 05:28 PM
olyelr's Avatar
olyelr
Originally Posted by Miami_Son
Hmmm...I'll have to check that out. If the front driveshaft is disconnected in 2 wheel drive then why the need for the CAD? Is it to stop the front axle from turning the driveshaft? Seems silly since it will turn from rotational friction anyway and the CAD is so prone to failure or damage.
Exactly, I totally agree with ya man. The whole front end in these trucks is stupid. If they would have just put a set of lockouts and real wheel bearings on the dang things from the git go we would all be better off.
Old Aug 10, 2009 | 05:29 PM
olyelr's Avatar
olyelr
Originally Posted by BigRedRam95
+1 on that my 95 will do the same but my dads 3gen wont
3rd gens wont cause they dont have a CAD.
Old Aug 10, 2009 | 05:31 PM
olyelr's Avatar
olyelr
Originally Posted by 99DRAM31887
thanks for all the help guys. when i have my 97 with the truck off, in park, and in 2wd my front drive shaft doesn't spin at all. his is a 95 and with his truck off and in 2wd his spins freely. when he drives it and is tryin to pass someone or something like that it makes a rattling noise. when i checked his drive shaft is when i found out it would spin freely in 2wd. and with the truck off the rattle is coming from where the transfer case meets the drive shaft.
The driveshaft SHOULD spin freely. The noise on the other hand, maybe thats a bad u joint?
Old Aug 10, 2009 | 06:37 PM
99DRAM31887's Avatar
99DRAM31887
ok well why doesn't mine spin when my trucks off ? i hate these front ends i agree you and miami son that would have been a better set-up
Old Aug 10, 2009 | 06:42 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Maybe the shift motor on the cad is not disengaging the fork fully.
Old Aug 10, 2009 | 06:56 PM
99DRAM31887
i don't know honestly i mean when i engage 4wd the light comes on and when i put it back in 2wd the light goes off :/ so im stumped.
Old Aug 10, 2009 | 07:25 PM
zman17's Avatar
zman17
Just because the lite goes on and off means nothing. Something could be wrong inside the CAD. If I could walk, I'd go out and see what mine does for the hell of it.
Old Aug 10, 2009 | 07:28 PM
speeddemon31176's Avatar
speeddemon31176
Mine spins free when the truck is not running and it is in two wheel drive. I agree with the idea that the CAD is not disengaged completely. You may have an internal component that is bent and not allowing the CAD to disengage completely.
Old Aug 10, 2009 | 07:46 PM
zman17's Avatar
zman17
Of course it could also be that the TC is in 4wd, like the lever needs adjusting, or it TC is hosed. I would raise the front wheels off the ground, get underneath and see if the shaft and the wheels spin. That would eliminate the TC anyway.
Old Aug 10, 2009 | 10:23 PM
Miami_Son's Avatar
Miami_Son
OK, I was underneath my truck most of the day and the front driveshaft does indeed spin freely with the truck off and in Park. When I thought about it I realized it made perfect sense. My last Dodge had full-time 4 wheel drive. I converted it to part-time with locking hubs using the knuckles and spindles off a Chevy 1/2 ton and a TC kit from I don't remember where. These RAM TCs have a 2X mode, which means they have no front output in 2 HI. I should have given it more thought before replying, but my ancient Dodge knowledge got the better of me. Still, it is a stupid setup. The CAD is so stupid an idea to put on an off-road truck I am astounded it lasted as long as it did. I mean, it wouldn't take much to snag the vacuum line or wiring on something and lose 4 wheel drive and get stuck. Even sitting on top of the axle it is prone to being damaged fairly easily. Bad design.
