Winding noise from rearend
Old Aug 12, 2009 | 05:15 PM
Gav1n8's Avatar
Gav1n8
okay and pour this new oil into the drain plug till it is at the bottom of the plug line? (mine has a drain plug) This is my job for tomorrow.
Old Aug 12, 2009 | 07:21 PM
Hammer Down's Avatar
Hammer Down
If the plug is midway up on the diff cover, it is only a fill plug and you will still need to remove the cover to drain the old fluid. Then fiil through the fill hole until the fluid is level with the bottom of the fill hole.
also, do not forget the friction modifyer. It should come in a 7 or 8 ouce tube.
Old Aug 13, 2009 | 04:46 PM
Gav1n8's Avatar
Gav1n8
okay when i pull this apart and hopefully i dont but if i do see metal flakes its time for new gears?
Old Aug 13, 2009 | 04:49 PM
Hammer Down
A little bit of metal paricles in the fluid is normal, but if it seems excessive, then I would say that the differential needs help.
