Help! 96 Ram 1500 cruise control problem.
Old Aug 11, 2009 | 05:54 PM
Vincep's Avatar
Vincep
Default Help! 96 Ram 1500 cruise control problem.
I changed the servo, switch and checked for vacuum leaks.There are none that I can detect. I'm getting 25 inches of Mercury, on my vacuum pump;which should be plenty. I checked various points in the vacuum lines, resovaur and the servo itself for leaks. All seems to be good.(to the best of my knowledge)
What happens is when I try to set the cc, It seems to engage, the pedal pulls down but speed is not maintained. Any ideas what the problem could be? Thanks.
Old Aug 11, 2009 | 07:37 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Try replacing the brake light switch .
Old Aug 11, 2009 | 09:26 PM
Vincep's Avatar
Vincep
What does that have to do with my problem? The brake lights come on and the cruise control does reset; when I hit the brakes.
Old Aug 11, 2009 | 09:37 PM
zman17's Avatar
zman17
How do you think the CC knows to shut off when you touch the brake pedal.
Old Aug 11, 2009 | 09:55 PM
Vincep's Avatar
Vincep
Good point. But like I said, the cruise does reset when I hit the brakes. However, since switches are cheap ,I'll give it a try.
I do appreciate your help.
Old Aug 11, 2009 | 10:12 PM
zman17's Avatar
zman17
It is cheap, or I wouldn't have suggested it in case I'm wrong,
Old Aug 12, 2009 | 01:02 PM
Vincep's Avatar
Vincep
If this doesn't work, what are other common possible causes of my cc symptoms?
Old Aug 12, 2009 | 01:42 PM
97black_ram's Avatar
97black_ram
I would say maybe the clock spring. I heard it mentioned before that it effects the cc and if it works or not. probably not the problem just a guess.
Old Aug 12, 2009 | 07:33 PM
Vincep's Avatar
Vincep
I changed the stop lamp switch and there is no improvement.
Old Aug 12, 2009 | 07:36 PM
Vincep's Avatar
Vincep
The cc throttle cable seems a little loose; at the throttle body. Are stretching cables a common cc problem?
