noisy steering system when turning left
Old Aug 17, 2009 | 11:06 PM
maddy63's Avatar
maddy63
Default noisy steering system when turning left
When turning left at any speed, I hear a slight grinding noise. PS Fluid is at the right level. Any ideas on where to start looking or tests I can run to isolate the problem?
1996 Ram1500 4x4, 5.9L
Thanks!
Old Aug 18, 2009 | 02:26 AM
Sheriff420's Avatar
Sheriff420
it may be your wheel bearings, jack the truck up and spin the tire to listen to it then grab the top and bottom of each tire and push/pull on it to check for movement. unless you mean that there is a grinding noise from the power steering pump, in that case i don't know.
Old Sep 1, 2009 | 04:38 PM
PistonPete123's Avatar
PistonPete123
I had a screeching/grinding sound when i turned left, it was a bad lower ball joint, maybe this will help you.
