Electrical Bull
Old Aug 19, 2009 | 09:17 PM
riggin99's Avatar
riggin99
Unhappy Electrical Bull
One thing that i hate the most is wiring....ok so i was drivin home from humbolt county and i was listen to my stereo it is a pioneer deck... i went to adjust my side mirror and the second i hit the lever to adjust it, my stereo lost all power the mirror wont work and even after that my dam dome light wont turn on. So i did the usual i checked the fuses inside the cab and those are ok... then what confused the hell out of me is that my CB (Which i hooked to the back wires of my stereo) still had power. So i ripped the deck out and there are two wires a constant (yellow wire) and a the other which gives power when i turn the ignition on (red) the rest are speaker wires... now the yellow which is constant has no power at all and when i turn the ignition the yellow still has no power but the red does... anybody have any ideas? i went to check the fuses in the engine bay and well i have no fuse box cover for it so i dont now what fuse is for what but none are blown... its nice to listen to the sounds of the 5.9 but i love my music
Old Aug 19, 2009 | 11:39 PM
dhvaughan's Avatar
dhvaughan
the constant power is to provide power on the presets and the clock. i don't know which fuse that comes from, but its likely something other than radio, maybe IOD (ignition off draw)
the one that's switched on/off via ignition is for the deck operation. its probably on a different fuse labeled radio.
i'll bet your radio fuse is blown even though it may not look like it. check it with an ohm meter.
Old Aug 20, 2009 | 12:50 AM
Trey318's Avatar
Trey318
DEF check the IOD fuse.
Old Aug 20, 2009 | 01:36 AM
oklahoma's Avatar
oklahoma
i had the same problem i couldnt figure out what was going on so i just ran a new wire fromthe power box with a 15 amp fuse to the yellow on my cd player i searched time and time again and months i didnt have power anything checked every single fuse atleast 10 times and found nothing so i just farmer engineered a solution lol everything worked from then on
Old Aug 20, 2009 | 05:24 AM
95MaroonMonster's Avatar
95MaroonMonster
if its not a fuse, electrical faults can be a bear to figure out
my clearance lights were not working, i kept burning the 15 amp fuse, searched for months, finally found it, it was a wire that had rubbed the inside of the body and the insulation had rubbed off, and was shorting on the body
Old Aug 20, 2009 | 02:12 PM
riggin99's Avatar
riggin99
ya the radio fuse is ok i checked it and then replaced it just for the hell of it, i think i did check the iod fuse ill double check again... thanks for the tips guys ill let you now how it goes... if all else fails ill just run a new wire
Old Aug 20, 2009 | 02:21 PM
riggin99's Avatar
riggin99
It was the IOD fuse thanks guys
Old Aug 20, 2009 | 05:45 PM
Trey318's Avatar
Trey318
I figured . Same thing happened to me.
Old Aug 25, 2009 | 12:58 AM
oklahoma's Avatar
oklahoma
where is the iod fuse? maybe that is what my problem was all along
Old Aug 25, 2009 | 01:31 AM
Miami_Son's Avatar
Miami_Son
Originally Posted by riggin99
ok so i was drivin home from humbolt county...
Checking up on your "garden?"
