Tranny Guru's, I need some help.
Old Aug 21, 2009 | 12:00 PM
buck6680's Avatar
buck6680
Default Tranny Guru's, I need some help.
Hi guys, Newbie to your thread. Thanks for having me. My problem, I've got a 98 1500 4x4 with a smoked tranny. My rebuilders and junk yard tell me that it has to be replaced with a 98 or 99 model only. After searching, I suspect that other model trannys will work with slight modifications. Is anyone familiar with a write up on interchangeability, or can someone give me some guidance on this? I found a tranny that was just rebuilt a short time ago in a truck that has been rolled, but it is a 96 model. Any help/guidance would be greatly appreciated.
Old Aug 21, 2009 | 01:13 PM
97black_ram's Avatar
97black_ram
It should be a 46RE transmission in your 98'. Also the trans. your looking at needs to come from a 4x4 ram also for it to hook up correctly to the transfer case. A guy name MonteC is our trans. guru.
Old Aug 21, 2009 | 01:27 PM
buck6680's Avatar
buck6680
Thanks for the reply. Yes, I have a bad 46re in my 98 1500 4x4 ram truck now, and the tranny I found is also a 46re, (with 6K mi since rebuild), but it is in a 96 model 4x4 ram. I have come across posts which would suggest that this transmission would work in my truck if I changed some sensors, etc. I have also come across other trannys while searching for a replacement, but as yet, haven't found a 98 or 99 with lower miles. My salvage yard and car-part dot com say a 98 & 99 are the only options I have to replace mine. I'm just looking for some direction as what models would work for me, and what mods I would have to do to make them work.
thanks again,
Old Aug 21, 2009 | 04:55 PM
Laramie1997's Avatar
Laramie1997
IMO, you would be much better off just paying more to have your current one rebuilt. Getting a used stocker out of the Junkyard is only going to give you another ticking time bomb on your hands. Might last 100 miles or 100,000 miles. You never know. Getting the one you have now rebuilt and beefed up a bit would be a sounder option. Not to mention you have the option to really make it stouter than stock configurations were.
Old Aug 21, 2009 | 05:22 PM
buck6680's Avatar
buck6680
Sound advice, no doubt, and I thank you for that. The tranny I found, was rebuilt less than 10K mi. ago, is supposed to be working perfectly, and is about $600 cheaper than having mine bench rebuilt. That is my incentive for asking these questions.
Old Aug 21, 2009 | 05:29 PM
Laramie1997
Is it worth the time and effort to try to move some sensors around? Are you going to be doing this yourself?
Another thing you don't know is what the quality of the rebuild was either....
Old Aug 21, 2009 | 05:48 PM
buck6680's Avatar
buck6680
Current owner says it's been working perfectly for near 10K mi., so I'm thinking that if it wasn't done properly, problems should have begin to show up already. To save $600, I am willing to change my sensors and your tires if need be, lol! Yes, i'll be doing it myself.
Old Aug 22, 2009 | 04:23 AM
xxxtina63's Avatar
xxxtina63
Smile
Good luck! Better have a good trans jack cause trans and transfer case is a hand full. Best of luck.
Old Aug 22, 2009 | 08:11 AM
buck6680's Avatar
buck6680
Thanks xxxtina63. I have a tranny jack, just not the info I am looking for yet.
