Fog light mod
Old Jan 15, 2010 | 05:43 PM
  #91
xjarhead69's Avatar
xjarhead69
Originally Posted by Capt. Obvious
good call. the 'st' in the name 'spst' means single throw which, for lack of better term, means one or the other.
Checkout this link.
http://www.therangerstation.com/tech...ry/relays.html
Dave
Old Jan 15, 2010 | 05:47 PM
  #92
011500Ram's Avatar
011500Ram
Ahh the good old Ranger Station!
Old Jan 16, 2010 | 11:28 AM
  #93
Sheriff420's Avatar
Sheriff420
ok, i believe i am right about the single throw relay. i believe that when not energized that the 30-87/87a posts are disconnected and the lever is just out in the open inside the relay, then when you energize the relay, it connects the 30 and 87/87a posts.
the double throw relay puts power to either 87 or 87a all the time.
so am i just reading the rangerstation site wrong? maybe i'm dyslexic, i dunno.
Originally Posted by wilfite
Dumb question: Anyone know where I can:
a) Find a readily available ACC wire in the cab (tried the one going to the radio, but it did strange things) and
b) Find a readily available backup-lights wire in the cab?
Thanks,
i used one side of the spare fuse slot in the fuse panel on the dash for my reverse lights.
my dads 98 doesn't have a spare slot, so i tapped the seat belt fuse for his fog lights with one of these
Old Jan 16, 2010 | 11:40 AM
  #94
Maxx_Magnum's Avatar
Maxx_Magnum
I just checked my rollbar lights relay and it has two 87 pins(not 87A), is this the same as an 87 and 87A? I have 1 light plugged into each 87 pin and they both come on
And I stole power from the fuse block also for the rollbar switch
Old Jan 16, 2010 | 03:31 PM
  #95
xjarhead69's Avatar
xjarhead69
That is the type of relay i am looking for, where did you get that relay from? If it came in a wiring kit can you get a replacement?
Thanks Dave
Old Jan 16, 2010 | 04:04 PM
  #96
mjackson92rs's Avatar
mjackson92rs
The relay you have is NOT the same type as Sheriff420 is talking about. Yours is correct, it has two 87 posts. The one Sheriff420 is talking about has 87 and 87A. The "A" distinguishes the terminals from normally opened and normally closed.
Old Jan 16, 2010 | 04:20 PM
  #97
Laramie1997's Avatar
Laramie1997
Sheriff, I took your first post and copied it over to the FAQ for a DIY.
https://dodgeforum.com/forum/2nd-gen...igh-beams.html
Old Jan 16, 2010 | 06:25 PM
  #98
Capt. Obvious's Avatar
Capt. Obvious
Originally Posted by xjarhead69
thanks for the link. very good explaination. i saw my mistake. guess my brain got full....lol
Old Jan 16, 2010 | 06:28 PM
  #99
Capt. Obvious
you nailed it on the head sheriff!
Old Jan 16, 2010 | 06:41 PM
  #100
meanwhitemopar's Avatar
meanwhitemopar
hey sherrif... dont get snippy with me too, but umm, i think the reason your new h1 fogs are so bright.. those are the same lights i have in my high and low beams ( progector lights) and you have them in the fogs... holy crow...
