A/C Issue
Old Aug 27, 2009 | 06:27 PM
  #21
Formosa Joe's Avatar
Formosa Joe
Question
I feel this would be a good place to start about mt a/c probs. I have a '95 1500 5.2 2 wheel drive Ram, just had a/c redone, new comp, new accum, new orifice tube, vacuumed and recharged ~ proper amount of oil in comp. and followed instructions to the "T". I am in south Texas, temp at time of recharge ~ 95 outside air blowing 40 inside ~ everything is cool (pun intended). Now when I am driving down the road at or above 40 the temp raises to around 75. When I get to a stop, cools back down.
HELP ??
Old Aug 27, 2009 | 06:34 PM
  #22
Johnboy11's Avatar
Johnboy11
WOW i love the wood grain dash ... Is that stock?
Old Aug 27, 2009 | 09:44 PM
  #23
Ram15002ndGen's Avatar
Ram15002ndGen
HELP ??
If everything was replaced and is working properly, then I would say you have an issue with now enough air getting across your condenser. You may need to check your Fan Clutch and see if that is free wheeling too much or if it is properly activating and blowing enough air through. Do you have a manifold gauge set? If so, hook it up and get everything up to operating temp, then while keeping an eye on your gauges spray your condenser with cool water and see if the pressure changes. If it doesn't, then you have a slugged condenser.
