gas mileage went way down
Old Aug 24, 2009 | 09:03 PM
  #21
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by 2damnyankee
i found my original build sheet and i got a 26 gal tank
Perhaps earlier on it was an option, and not standard like it was in later model years.
Old Aug 25, 2009 | 01:10 AM
  #22
Ramman18's Avatar
Ramman18
All the websites that contain specifications only list the 26gal and 35gal tanks for 1995. As previously posted, the short bed trucks had 26gal tanks. However, I seem to remember reading that Ctd and V10 shortbed trucks had the 34 gal tank.
Old Aug 25, 2009 | 12:06 PM
  #23
cmckenna's Avatar
cmckenna
no the fuel rails are clean and the injector's are spot less. air supply is clean and all the sensors are new IAC, MAP,TPS and the O2 before the cat. plus the cat is hollowed out now. i was woundering if that may be the cause of it not getting any back pressure now that I reamed it out.
How do you know the inside of the fuel rails are clean? If it's a 95, which is only one year older than mine, there may be rust in them. I live out in LA where it is bone dry almost and mine were loaded with rust on the inside. It was pooring out all over the bench. Have you removed them and inspected them? Have you performed a flush through a filter to see if any debris comes out? Spotless on the outside means nothing when it comes to the internals. Are those new injectors or old injectors? Has anyone done a spray test on them to ensure that the flow is not restricted?
If all proves to be clean and up to par, I would find it safe to say that it's probably not tuned in yet. Give it some time and to relearn and then compare it.
Old Aug 25, 2009 | 07:40 PM
  #24
2damnyankee's Avatar
2damnyankee
the fuel fuel rails are brand new when i did the plenum less than a month ago. second i took the injector's over to a friend of mine that works for dodge and he hooked them up to the injector cleaner for (cost me a whole case a beer ) i love it when people work for beer.
Old Aug 25, 2009 | 07:55 PM
  #25
Rockyhigh360's Avatar
Rockyhigh360
I get about 9.5 in town with my superchip set to 87 oct. When I bought it, I got 15 in town and 18 on highway.
Old Aug 25, 2009 | 08:32 PM
  #26
Ram15002ndGen's Avatar
Ram15002ndGen
^^ That makes no sense at all. Why would you be running the super chips if it causes you to loose mileage? It sounds like you were better off with the stock program.
Old Aug 25, 2009 | 08:35 PM
  #27
cmckenna's Avatar
cmckenna
Oh, ok, yours are new. That works. Out here they charge a boatload for cleaning injectors.
Old Aug 26, 2009 | 06:38 PM
  #28
Rockyhigh360
If I wanted good gas millage, I would by a civic, except they're kinda hard to wheel @ 12,000 feet.
