Noise when gas pedal is pushed
Old May 1, 2013 | 10:46 AM
  #21
merc225hp's Avatar
merc225hp
I use a propane torch (no flame) for finding vac leaks works great and is somewhat safer than other flammables.
Old May 1, 2013 | 06:06 PM
  #22
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by 1500ram99
i just replaced my plenum gasket and intake gasket and cleaned the iac and a shop checked all my vacuum lines and they all checked out ok, its making a whistling noise only when i accelerate and it doesn't seem to have the power it should when i accelerate. its also burning oil somewhere, it doesn't leak it just burns it out the exhaust that i haven't found yet. tested my head gaskets and they were good
Cleaning the IAC does not mean it's working correctly. And is the round gasket on top of the throttle body to air intake installed? And after plenum fix, was anything done about the cat and o2's?
Old May 1, 2013 | 07:05 PM
  #23
Silver360's Avatar
Silver360
My truck has done something similar since the day I've gotten it. Minor increase or decrease on throttle makes a tiny squeak but it's at the pedal. Sounds like I'm stepping on a mouse or something. Doesn't happen much in city driving but somewhat often on the highway.
Old May 2, 2013 | 12:37 PM
  #24
JKresge's Avatar
JKresge
Thanks to this forum I fixed my "turbo" issue last night with the $1.99 gasket on top of the TB. Also when replacing it make sure that the clamp is on there correctly or your snorkel isn't going to seal properly. Mine was off on the passenger side when I first reinstalled it.
Old May 2, 2013 | 12:41 PM
  #25
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Something I've found with my air cleaner is that if you open up the clamp much larger than the throttle body lip, press down on both sides of the clamp, THEN tighten it down, you'll eliminate most sealing issues.
Well, once you get the hang of it, that is.
Old May 2, 2013 | 04:54 PM
  #26
zman17's Avatar
zman17
+1, that's exactly how I do it. Opening up the clamp more makes it a lot easier to seat the air hat properly.
Old May 3, 2013 | 01:58 AM
  #27
ReadRam's Avatar
ReadRam
nevermind.
Old May 3, 2013 | 07:19 AM
  #28
Chroma's Avatar
Chroma
Check your exhaust flange. Might need replaced.
