Did the 46RE have an outboard filter?
Old Aug 30, 2009 | 02:59 AM
  #21
jasonw's Avatar
jasonw
Site Moderator
Yup, Laramie is right. ATF+4 replaced ATF+, ATF+2, and ATF+3, it is the latest/greatest and is superior to the previous three. It can be used for anything the previous three were used for.
Old Aug 30, 2009 | 10:16 PM
  #22
Ram15002ndGen's Avatar
Ram15002ndGen
Yea, if you want a good chuckle open up the owners manual (for those who have it). On my owners manual for a 97, it says to use ATF+2. Sadly that went away like right after the truck was made, and recently ATF+3 went away too. If you can find it, that would be amazing to say the least. Anything you find now will be ATF+4. If you have a WalMart near by you can get MOPAR ATF+4 for around $4.00 a quart. If you go to the dealer it's like $10 a quart.
Oren don't worry about it. I put in ATF+4 mixed with my old fluids and it has made no difference at all, it seems to be safe. All the 00 and newer trucks I think already have ATF+4 in them anyway.
Old Aug 30, 2009 | 10:28 PM
  #23
Laramie1997's Avatar
Laramie1997
Oreily's keeps it in their house brand, Valvoline, and Castrol. They are all about 3.xx a quart.
Old Aug 30, 2009 | 10:48 PM
  #24
Oren09's Avatar
Oren09
I'm stuck with NAPA. Nearest WalMart is 80 miles. I do miss Texas for the O'Reilly's...
Old Sep 1, 2009 | 08:50 PM
  #25
DODGEIT105's Avatar
DODGEIT105
2001 was the first year to require ATF+4. It is a full synthetic. ATF+3 is a semi synthetic. You can run the ATF+4. It won't hurt it. Might even improve the shift.
Old Sep 1, 2009 | 08:56 PM
  #26
PurplDodge's Avatar
PurplDodge
Also, AllData says ATF+3. Should I use ATF+3 or ATF+4?
ATF+3 isnt even made anymore. ATF+4 is all you should use.
I just used Coastal ATF+4 from Autozone. The $3 was cheaper than the $6 Valvoline.
Laramie if you go to the Mopar Nationals next year, I will change your tranny fluid, filter, and install an external filter for a small fee of only $24.95. I may even adjust your bands!
Old Sep 1, 2009 | 09:12 PM
  #27
Laramie1997
^Pass.....
Old Sep 1, 2009 | 09:30 PM
  #28
PurplDodge's Avatar
PurplDodge
C'mon! I'll bring my Harbor Freight torque wrench!!!!
BTW never buy a torque wrench from Harbor Freight...
  #29
Laramie1997
Pass...
