need a tranny where do i go?
Old Sep 1, 2009 | 12:26 AM
Ram15002ndGen's Avatar
Ram15002ndGen
With family members like that, who needs enemies?
Old Sep 1, 2009 | 04:56 AM
palerider9999's Avatar
palerider9999
4x4 if you are still monitoring your post, I have seen a few on craigs list at a decent price. Also check to make sure you get the right year for replacement. I know the 98 and 99's are a different animal but can be modified to work. Not sure of the part you need to switch over. Also get you tranny cooler and lines professionally flushed and make sure the check valve near the radiator is either removed or cleaned. Don't use your old torque converter either.. Sounds like you need to file a small claims action suit against your uncle and recover some of your loses. Good luck..
