Seafoam?
Old Oct 24, 2009 | 12:55 PM
lastrights's Avatar
lastrights
yeah i use the brake booster while as friend gives it some gas so it wont stall, let it take half bottle or whatever, let run for a min shut off for 15-30 mins start up and watch a smoke show
cleans pretty well, i had a better idle and smoother acceleration
Old Oct 24, 2009 | 12:57 PM
95RAM360's Avatar
95RAM360
should hold the RPMS to about 2000
and the smoke comming out the back is it flushing out right? how do you drain out safoam? (never done it as well)
Old Oct 24, 2009 | 01:04 PM
nathangfnd's Avatar
nathangfnd
well i have heard that you run it in your oil for a few miles than do an oil change. but i have never heard if you need to do anything else.
Old Oct 24, 2009 | 01:05 PM
Eddielx's Avatar
Eddielx
http://www.youtube.com/watch?v=D11ZVYwj62w
Old Oct 24, 2009 | 01:11 PM
nathangfnd's Avatar
nathangfnd
so is it smart to change the oil after a few miles or is it ok to be in there.
Old Oct 24, 2009 | 01:20 PM
zman17's Avatar
zman17
Retired Moderator - RIP
If you have been using quality oil and changing it when you should, don't bother putting it in the oil. Put 1/2 in the brake booster hose(pour it in slowly so the engine does not die) let it sit as stated above. The rest put in the gas tank.
Old Oct 24, 2009 | 01:27 PM
nathangfnd's Avatar
nathangfnd
so quick question where is the break booster located. probably seen but never worked on it
Also do i pour it directly in or is there a hose connected to it
Old Oct 24, 2009 | 01:33 PM
zman17's Avatar
zman17
The brake booster is the big round thing behind your master cylinder. Disconnect the hose from the elbow and pour it into the hose not the brake booster. And do it while it is running, besides, the can has directions on it.
Old Apr 30, 2011 | 09:32 PM
timekop's Avatar
timekop
Default Hose location
This may help a bit. The hose is hiding in plain sight. When you remove the hose with the engine running, you will here the vacuum or sucking sound. It's very obvious.
Old May 1, 2011 | 12:35 AM
CPTAFW163's Avatar
CPTAFW163
Just do what zman is saying, DO NOT put it in your oil. If you want to free yourself of sludge, just get a synthetic oil change special from autozone EVERY THREE MONTHS OR 3K miles. After one year, your engine will be free of sludge. I have changed the oil in my truck 6 times over the past 10K miles and my engine is very clean. No baked on crust on my valvetrain.
Synthetic oil flushes your system, and it does not do it in one go. If you flush all the crud in your engine and it ALL gets through your oil pump...it will get clogged. Syn oil does it gradually over time.
