Still bouncing
Old Sep 13, 2009 | 01:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It is entirely possible that you have bent hubs/axles on the rear from the beating on them .
Old Sep 13, 2009 | 06:51 PM
Kindschi's Avatar
Kindschi
I'd say its a balance issue, espically since you can time it based on the speed of the truck which means its cause is the Wheel/Tire and not the road.
Old Sep 13, 2009 | 06:59 PM
cmares's Avatar
cmares
I did that, there was 1 rim a little bent. I put on another rim.
Old Sep 13, 2009 | 07:53 PM
onegoodmason's Avatar
onegoodmason
why not pull the frt drive shaft , process of elimination . I would not be surprised to know either the frt or rear was out of balance
Check the motor and trans mounts
Old Sep 13, 2009 | 09:26 PM
chris101's Avatar
chris101
I dont see how this is possible. But I bet you warped the rim
Old Sep 14, 2009 | 07:38 AM
zman17's Avatar
zman17
Why would it not be possible? Depending on how hard they were beating and how much heat was applied. I'd raise it, remove the wheels and drums. Start the truck and put it in first and see if there is any noticeable wobble in the end of the axle. You might also notice that the drum was scraping on the back plate at first.
