Tools for Manual Transmission 96
Old Sep 6, 2009 | 10:09 PM
Shadow3865's Avatar
Shadow3865
Question Tools for Manual Transmission 96
I have a 96 ram 1500 with a manual transmission what are size of tools that I would need to service it. It has way to much fluid in it and it is coming out of the top of it. I would like to fix this problem at a low cost to me. Do you have any ideas that would help me to get this job done at low cost.
Old Sep 6, 2009 | 11:34 PM
95MaroonMonster's Avatar
95MaroonMonster
yea, open the fill plug, and let the excess drain out
Old Sep 6, 2009 | 11:35 PM
Hahns5.2's Avatar
Hahns5.2
The drain and fill plugs are 17mm allen. I found a big 17mm allen wrench at Napa for mine. I prefer to fill mine through the shifter hole, sounds like you need to take the shifter off and re seal it anyways because I doubt it's overfilled. Mine is overfilled and doesn't leak.
Old Sep 7, 2009 | 03:46 AM
Ramman18's Avatar
Ramman18
My napa didn't have the wrench. So I found a bolt head that fit into the plug, cross tightened two nuts on it, stuck it in my ratchet and voila! Instant tool. Make sure you get the Mopar oil for it. It should take 1 and a half quarts roughly. I just fill til it runs out. I agree with the leak however, as it shouldn't. But there is a weep/vent hole on top somewhere because I've noticed it wet sometimes.
Old Sep 7, 2009 | 04:39 AM
Hahns5.2's Avatar
Hahns5.2
Syncrhomesh is a lot easier to find, cheaper and spec'd for these trannys.
Old Sep 7, 2009 | 10:56 AM
Shadow3865's Avatar
Shadow3865
Well I have 3 quarts already because of some friends of mine help me replace the clutch. so they add a little bit through the top of the shifter. I will look into the seal this morning and go head and replace the seal on the shifter & while I am doing that I will also pick up the 17mm allen wrench from sears. I like having tools that have a life time warranty because I tend to brake them sometimes.
Thank you for all your help on this.
Old Sep 7, 2009 | 11:42 AM
Shadow3865's Avatar
Shadow3865
What is the tool called to remove the clutch arm?
Old Sep 7, 2009 | 12:01 PM
Shadow3865's Avatar
Shadow3865
It is called a clutch arm puller. Does any one have any ideas where I might try to get one at?
Old Sep 7, 2009 | 01:01 PM
Hahns5.2's Avatar
Hahns5.2
Clutch arm? Not sure what you're talking about..
I seal my shifter to the trans with a thin layer of RTV, seems to work quite well.
Old Sep 7, 2009 | 02:21 PM
Shadow3865's Avatar
Shadow3865
okay it was just the seal on top of the shifter arm that had to be replace. & It is a dealer part. So I add silicon on it and it worked like a charm.
