Issues with disconnecting a battery?
Old Sep 7, 2009 | 08:10 PM
dbasmb's Avatar
dbasmb
Default Issues with disconnecting a battery?
These days, just disconnecting a battery can give you problems...apparently the computer needs to be reset on some cars when the battery is disconnected. Any issue like that on a Gen 2 Dodge??
Thanks,
Doug
Old Sep 7, 2009 | 08:13 PM
DODGEPWR's Avatar
DODGEPWR
Ive unhooked my batt for hours before..while i worked on the truck. Didnt notice any difference when i hooked it back up. They say it has to relearn and take around 200 miles for it to relearn. But like i said after i unhooked mine, I didnt have anyprobs.
Just have to reset your clock on the radio.
99DRAM31887's Avatar
99DRAM31887
no just un-hook it and you'll be fine. Once you do un-hook it you will have to reset your radio and junk but nothing major and this is also a fix to your cel codes just disconnect your battery and it will reset the pcm.
Old Sep 7, 2009 | 08:41 PM
dhvaughan's Avatar
dhvaughan
there's no problem with disconnecting the battery on any vehicle. its one of the first things you should do for a lot of service issues.
loss of power triggers a computer reset, but that doesn't hurt anything.
it simply returns to the default settings and starts relearning the fine-tune settings.
sort of like rebooting a computer - sometimes its just sort of good for it.
any vehicle that couldn't survive a battery disconnect without a trip to the dealer would be completely useless.
Old Sep 7, 2009 | 09:03 PM
Miami_Son's Avatar
Miami_Son
Correct me if I'm wrong, but I don't think simply disconnecting the battery will reset the PCM. Don't you also have to turn on/off the ignition in a sequence while the battery is disconnected to do that?
Old Sep 7, 2009 | 09:08 PM
Laramie1997's Avatar
Laramie1997
Eh, if you leave it unhooked for awhile, it will reset. Most of the time, just leaving it unhooked for a minute will kill it left over charge. Consider, you have draw on the battery even when the cables are unhooked.
Old Sep 7, 2009 | 09:19 PM
dhvaughan's Avatar
dhvaughan
the capacitors that hold power on the memory have to give out in order to reset. that can be accomplished by leaving the battery disconnected for awhile (not sure how long) or with battery disconnected - turn ignition to start, or turn on headlights to drain them quick.
