Downshifting Question
Old Sep 9, 2009 | 06:21 PM
lblair04's Avatar
lblair04
Default Downshifting Question
I drove a 00 Ram the other day that Im looking into buying. 360 auto. When I gave it gas, and it downshifted, it was pretty smooth. In my 97 F-150 I used to have you could definately feel it kickdown. Is it normal for the Dodge tranny to be smooth??
Also, when I go to start it cold, you have to let it turn over a few times, let go of the key, then turn it over again to start. Only when cold... What could be the problem? The owner said he has taken it to the dealer for it and they said they cant find anything wrong... Could it just need a tune up?
Thanks
Old Sep 9, 2009 | 07:00 PM
Aubrey's Avatar
Aubrey
It will probably be fairly smooth. It's all what you consider smooth though.
Maybe. Or a fuel issue. Or something more severe.
Old Sep 9, 2009 | 07:04 PM
lblair04's Avatar
lblair04
He said its been doing it for awhile and hasnt gotten worse. Doesnt recall changing plugs/wires in the ~5 years he had it. Dealer did all the work...which I hear thats not a good idea. I will be giving it a tune up.
Old Sep 10, 2009 | 01:21 AM
dakotas ram's Avatar
dakotas ram
does it seem overall underpowered? mine shifted pretty firm and even firmer now with the shift kit
Old Sep 10, 2009 | 01:27 AM
Miami_Son's Avatar
Miami_Son
The starting issue sounds like the fuel system might be losing pressure over time. May need a new fuel pump sooner rather than later.
Old Sep 10, 2009 | 02:32 PM
crazzywolfie's Avatar
crazzywolfie
you could try priming the fuel system before you start it.
Old Sep 10, 2009 | 03:56 PM
HappyLongBed's Avatar
HappyLongBed
I had a simliar symptom to you at start up. My coil was bad. $35 part and 15 minutes to replace and it starts within 2 seconds now.
Old Sep 11, 2009 | 02:30 AM
lblair04's Avatar
lblair04
Thanks! How do I go about checking the coil?
Old Sep 11, 2009 | 01:50 PM
DODGEPWR's Avatar
DODGEPWR
Well, When i replaced mine it only took like 3 minutes... Taking out two screws and unpluging the coil wire and connecter are extremly easy. Very simple. If you can wash a car, you can replace a coil.
Its easy, But you need an OHM meter or you can use an old spark plug........Try
Oh yea, dont get a duralast part. Go to advance auto and get a BWD coil.
Old Sep 12, 2009 | 12:58 PM
crazzywolfie
you know trying to prime you fuel system is something you should try before you go spending money where you don't have to. all you have to do is keep turning your key on and off till your fuel pump stops making any noise when you turn the key on then try starting it. if it fires right up then i would not worry about the coil.
