Question with 3 inch lift.
Old Sep 10, 2009 | 08:43 PM
98BlueSport's Avatar
98BlueSport
You have any pics of your truck yet?
Old Sep 10, 2009 | 08:45 PM
dodge15004x45.9's Avatar
dodge15004x45.9
http://s757.photobucket.com/albums/xx217/dodge15004x4/ look at my pics in my albums to see it stock.
Old Sep 10, 2009 | 09:18 PM
360mag45's Avatar
360mag45
just throwin this out there but my lift is from procomp and it came with new shocks and it just was spacers a 3" block that went on top the coil and the back was an add a leaf and i thinck a 2" block. but you have a sport so this might not work im not shore. obw it was an easy do it yourself job might save you some $$$$ idk
Old Sep 10, 2009 | 09:21 PM
dodge15004x45.9
Did you put the leafs in?
Old Sep 10, 2009 | 09:52 PM
360mag45's Avatar
360mag45
yeah it was just one leaf u just took the u bolts off droped the rear down alittle then put the add a leaf in lined everything back up and put the block on and re bolted everything up i thinck there is a centering pin in ther i forget now but i didn't need a torch
Old Sep 10, 2009 | 10:13 PM
dodge15004x45.9
Mine leaf is long as hell. Its a full lenght leaf.
Old Oct 7, 2009 | 01:16 PM
BlueNite's Avatar
BlueNite
Question for you guys... We just ordered my brother the 3inch suspension lift from Top Gun Customz. Its the one with the coil spacers, 2 shocks, rear blocks and U bolts.
I got to looking at his truck the other day. Its a 97 Ram 1500 4x4 ext.cab. Im not a Dodge guy so this may sound stupid but...the trucks I have worked on are my Titan and My F150, bot when I added coil spacers were on a Coil/over or a coilspring. What is on his truck looks like a coilover with a big dome over the top that raises up almost to the top of the fender well. what the crap is that? Will that lift still work with it?
Thanks guys I just want my ducks in a row when I go to install this thing, hunting season is right around the corner and time is running out...>LOL
Old Oct 7, 2009 | 01:36 PM
dodge15004x45.9
Not sure what your asking but when I did my 3" lift it was fine. I used all the factory stuff and the new bolts. FYI you should have 4 new shocks not just 2.
Old Oct 7, 2009 | 02:00 PM
TIMIDONE's Avatar
TIMIDONE
does everyone suggest top gunz to buy the add-a-leaf for the rear? Someone got a link? Need to price it all out...been wanting to do for a LONG freaking time.
Old Oct 7, 2009 | 02:10 PM
BlueNite's Avatar
BlueNite
Sorry my description pretty much sucked...
Instead of the shock sitting inside the spring and stopping at the top of the spring like a standard coil/over their is a Dome looking thing that is on top of the mount (coil bucket) that the shock runs up and bolts to. Im sorry man I will try and get a picture of it.
and their is only 2 shocks, 1 for each side of the front....This kit only came with a 1.5 inch block and dont need rear shocks I guess....
