Question with 3 inch lift.
Old Sep 9, 2009 | 08:13 PM
98BlueSport's Avatar
98BlueSport
Default Question with 3 inch lift.
I have a 98 Sport 4x4. And I am looking at options of lifting it up. I only want to go 3 inchs. And I'm pretty sure I want to go through top gun customz. Now i'm just looking for personal opinion pretty much.
Option 1.- 1 ton coils up front and add a leafs in the rear. with new shocks all the way around and new lower control arms.- Are the 1 ton coils going to make the truck ride like a tin can?
Option 2.- Go with the 3 inch coil spacers and a 1 inch block in the rear. Now I dont really like the idea of stacking blocks. And i feel the front is a little too soft as it is.
Option 3.- Mix n match either spacers and add a leafs. or 1 tons and blocks.
Basically I'm just looking for opinions here, pros and cons. I'm open to anything you guys have to say. I'm 18 and can do all the work myself, I'm just looking for what you have done and if you like it over another way.
thanks
Old Sep 9, 2009 | 08:20 PM
DodgeKid88's Avatar
DodgeKid88
Hey. Im planning on doing a 3in lift aswell ,but i bought 2500 V10 coils. And Im doing eather a 5in block or an add a leaf for the rear. Iv been told that the V10 coils will net you about 3in lift and the V8 2500 only about 2in. Good luck.
Old Sep 9, 2009 | 08:49 PM
olyelr's Avatar
olyelr
I lifted my truck with diesel/V10 coils and gained just over 3" of lift. Sure, it rides much more stiff, but the stock coils are too soft anyway (in my opinion).
For the rear I used two add-a-leafs and it leveled it off perfectly.
I went this route for the cheapness of it. If I had the money I would have just bought a kit, but this has worked well for me (have had it installed for nearly 10 years now).
You will need new shocks in the front for sure, everything else is not NEEDED (control arms, track bar lowering bracket, dropped pitman arm etc...). For proof; I am still on my factory installed track bar and tire rod ends, which is even unheard of in a stock height ram at 160k miles!!!!!
Old Sep 9, 2009 | 08:52 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Top guns is a killer place nice people. I went with the new coils I'm glad I did I can hit speed bumps doing 30 and the front end barly dips now. The new coils where 3" taller and 2x as thick as factory. FYI You will need a 2" block. For the leafs one in each pack. The problem with the leafs are. You have to heat and undo the metal bands on the packs which you need a torutch to do. (unless someone is willing to shed some light on this. I never put there control arms in. There the same as factory. I'm pretty sure you sent me a pm on this a long time ago?
Old Sep 10, 2009 | 03:11 AM
Ramman18's Avatar
Ramman18
I'm in the same boat. I bought 3" coils from Skyjacker and plan on AAL for the rear. Did I read that right dodge1500^^^ that a block is also needed with the AAL?
Old Sep 10, 2009 | 03:17 AM
dodge15004x45.9
For a 3" lift a 2" block is needed. If you put in the add a leaf you do not need the 2" block.
Old Sep 10, 2009 | 01:51 PM
98BlueSport
Yea so coils up front is prolly the way to go then?
Old Sep 10, 2009 | 04:19 PM
zje400ex's Avatar
zje400ex
If i were to do it all over again i would have bought 3" lift coils or diesel coils instead of my 3" coil spacer. The nice thing with the spacer is that it keeps my factory ride. I bought mine from top gunz and now they just dropped the price on their spacers...figures
Old Sep 10, 2009 | 04:23 PM
DodgeKid88's Avatar
DodgeKid88
I would go with 3in coil. Just check your local auto salvage yard for 1 ton or 2500 V10 or diesel coils. I bought mine on shelf for 40 bucks! Little rusty but nothing a can of paint could fix!
Old Sep 10, 2009 | 07:53 PM
dodge15004x45.9
Why would you want to keep the ride factory? I like how much stiffer the new coils made my front end. Before if I hit a bump I would have to slow way down. No I can hit it at speed and the front end bearly dips now.
