Should I replace my upper balljoints?
Old Sep 12, 2009 | 07:26 PM
revvinram's Avatar
revvinram
Default Should I replace my upper balljoints?
I noticed that my upper sealed balljoints the boot is torn (they were replaced about 4 yrs ago), It doesn't appear to have any play in them at this time.. Whats your opinion?
Old Sep 12, 2009 | 08:13 PM
Miami_Son's Avatar
Miami_Son
Just because the boot is torn? If the ball joint is still good and working you can get new urethane boots from Energy Suspension.
Old Sep 12, 2009 | 08:25 PM
revvinram's Avatar
revvinram
Miami,
Took a look at their website didn't see them??
Old Sep 12, 2009 | 08:36 PM
Miami_Son's Avatar
Miami_Son
Might have been Rancho. Don't remember where I saw them, but I did.
Old Sep 12, 2009 | 09:11 PM
97black_ram's Avatar
97black_ram
You should be able to get a new boot at most local parts stores.
Old Sep 13, 2009 | 05:07 AM
speeddemon31176's Avatar
speeddemon31176
Energy Suspension definitely carries new boots for both ball joints and tie rod ends for just about any vehicle you can think of. Like 97Blackram said, you can also get new boots from the part store depending on what your preference is, is what you should purchase. Either one will work.
Old Sep 13, 2009 | 08:11 AM
revvinram's Avatar
revvinram
I checked parts stores no luck there either, or at rancho.
Old Sep 13, 2009 | 09:23 AM
dhvaughan's Avatar
dhvaughan
you'll have to separate the knuckle out to replace the boot.
sounds like a lot of work to me.
i'd just grease them and leave them alone.
Old Sep 13, 2009 | 09:34 AM
aim4squirrels's Avatar
aim4squirrels
+1 get a good thick axle grease and stuff the boot full in the crack. That will keep out the water, road debris, and brake dust. Then just check them at each oil change.
Mine have been torn for 2 years at least and this has worked well for me.
Old Sep 13, 2009 | 09:40 AM
revvinram's Avatar
revvinram
dhvaughan,
Since they are greaseless balljoints (no zerk fitting) thats kind of difficult to do... I have had a friend of mine recommend spraying some white lithium grease in the busted boot, whats your take on it?
Thanks..
