Holley throttle body?
Old Sep 15, 2009 | 06:57 PM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
It's just a motor, I think you are reading more into this than is actually required. And he doesn't need to swap the pcm if he changes the manifold. And any of the other sensors on the motor(crank and ECT) that don't have matching plugs can just be swapped. So I might be wrong about making it as simple as swapping the intake, but it's not as complicated as what you are stating. Btw, I'm not arguing, just having a friendly debate,
Old Sep 15, 2009 | 07:08 PM
  #22
Miami_Son's Avatar
Miami_Son
I'm just saying there are incremental differences in PCM programming over 3 years and between an OBDI and OBDII engine. If he was just using the block then there's probably be less of an issue, but I assume he wants to use the whole engine, in which case he will likely need to take the PCM, harness and any sensors from the older engine with it. I don't think it is as simple as dropping in the older engine with the PCM, wiring and sensors already in place and having it run fine.
Now could someone tell me why my sig pic is so small all of a sudden?
Old Sep 15, 2009 | 07:32 PM
  #23
BlueBeast2's Avatar
BlueBeast2
Cause your a mod now you don't matter so you have a small sig . Not sure why you would want to this myself OBDII has much more options when you go to mess with it tuning wise
Old Sep 15, 2009 | 07:37 PM
  #24
Augiedoggy's Avatar
Augiedoggy
zman17 isnt saying to replace the OBD11....he is saying to take all the uncompatible sensors off the 95 motor and retain all the wiring/computer from the 98 ands leave it in the truck....just basically swapping the block and maybe intake..... at least thats how I understood it from the beginning?
Old Sep 15, 2009 | 07:40 PM
  #25
zman17's Avatar
zman17
The engine itself is the same, and by the time all the accessories are removed along with the intake, it is basically just the block.
Old Sep 15, 2009 | 07:46 PM
  #26
BlueBeast2's Avatar
BlueBeast2
True but the way we are looking at it he's just gonna drop it in not change a bunch of crap. Which ain't gonna work so well
Old Sep 15, 2009 | 07:50 PM
  #27
zman17's Avatar
zman17
You are not going to put an obd1 pcm in a obd2 truck, you might get the motor to run, but nothing else on the truck will work.
Old Sep 15, 2009 | 07:51 PM
  #28
zman17's Avatar
zman17
Exactly.
Old Sep 15, 2009 | 07:57 PM
  #29
BlueBeast2's Avatar
BlueBeast2
yes now heres the thing. You could have totally different sensors on the 95 which was said. I know for a fact that on Mustangs the older (fox's are different then the sn's and they both had a 302 5.0) years have a totally different sensor like not even close to being the same, different shape and all. Not sure how that is on dodges but say you have that issue then what are you gonna do. He would have to tear it down to the block and rebuild it. Which its possible he wasn't planing on doing.
Just a thought
Old Sep 15, 2009 | 08:04 PM
  #30
wjxavier's Avatar
wjxavier
i just have a feeling that it wont work like it should. i guess we'll see won't we. lol
oh btw...i'm about 99.99% positive that you CAN'T swap a single core processor for a dual core processor and keep the same motherboard. the pins wouldn't even line up. not even close.
