Ram wont start
Old Sep 18, 2009 | 06:34 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by Gotta feed them horses
I am also going to try and find the pressure release for the fuel line on the fuel rail and see if the pump is building any pressure.
If you don't use a tester, don't waste your time. Anything other than no pressure at all, will tell you nothing.
Old Sep 18, 2009 | 04:00 PM
Gotta feed them horses's Avatar
Ok, spark is good. I can't hear or feel anything from the pump and the plus were dry after trying to start it. I couldn't find where the fuel line connects to the engine so I didn't actually see no fuel being pumped. I'm going to replace the relay. Anything else I should try? Thanks. What are the best pumps? Bosch, Delphi,....?
Old Sep 18, 2009 | 06:43 PM
zman17's Avatar
zman17
Is your fuel rail plastic? If it is, you need a special adapter to check the pressure, which I have, but thats besides the point. You are going in the right direction by replacing the relay,(which btw you can just swap the horn relay). Other than making sure you don't have a bad ground or broken wire some where,I'd say the pump is shot.
