97 dodge front hub. PITA
Old Sep 20, 2009 | 08:47 PM
killerbee8342's Avatar
killerbee8342
Exclamation 97 dodge front hub. PITA
HI im new here and i have a 97 4x4 dodge 5.2. the front driver side u-joint is on its way out and i went to go replace it today. I got everything off except for the hub. The roter brakes and all three bolts on the hub came out. But it dosent want to brake loose. Any sugestions. Any help would help thanks.
Old Sep 20, 2009 | 08:59 PM
Mega-Hemi's Avatar
Mega-Hemi
Air chisel or big azz hammer and chisel on the 3 flats between each bolt hole on the hub. Start swingin' and have fun. Just don't chisel where the bolt holes are. Did that my first time and oblonged the holes, new hubs aren't cheap.
Old Sep 20, 2009 | 09:09 PM
killerbee8342
alright so when i get the hub off i should be able to slide the whole axle shaft right out. Right? Or do iave to remover the ball joint too?
Old Sep 20, 2009 | 09:16 PM
Mega-Hemi's Avatar
Mega-Hemi
It will slide through the hole in the spindle.
Old Sep 20, 2009 | 09:24 PM
Miami_Son's Avatar
Miami_Son
There are a ton of threads about this in here. Basically, you need to soak it with a penetrating fluid, usually overnight or longer. Try doing a search as there's a thread with a really good DIY with pictures.
Old Sep 20, 2009 | 09:39 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Put some *** into it boy!
Old Sep 20, 2009 | 09:55 PM
offroadjosh's Avatar
offroadjosh
2% rule..... Gotta be 2% smarter than the object your working on! ha jk, but really every truck i have had to replace hubs or had to pull shafts out of you really have to beat the snot out of it.
Josh
Old Sep 20, 2009 | 09:59 PM
killerbee8342
I usually beat the snot outa stuff. But i wanna take it easy with the hub, because they are a bit pricey. The number one tool in my tool box is the sledge hammer. and number 2 is the pry bar.
Old Sep 20, 2009 | 10:55 PM
Miami_Son's Avatar
Miami_Son
Sissy. That's what screwdrivers are for.
Old Sep 20, 2009 | 11:09 PM
devramstuff's Avatar
devramstuff
I usually thread the bolts in a couple threads and hammer them from the back of the knuckle. I tried with a chisel before that, but it started to bend the tabs.
