truck just died
from my expierence and with my high school shop teachers knowledge/help with crank sensors they pretty much either work, or dont work, there is no in between.
though i did read on allexperts that the asd relay will trigger when there is no cam, or crank signal. and it was on a 99 dakota with a 5.9 so im not sure if it would be the same. i think i might look into one of these senors, as i now know that one of them could be goin out, or losing connection. hmm...ponders a bit
http://en.allexperts.com/q/Chrysler-...e-dakota-2.htm
So, it's not just black and white / on / off with these things. FYI
That is not true about it working or not. I just put in a new one two days ago and, the idle was all over the map and fine the next all with the same sensor. Sometimes they deliver low-erratic voltage while sometimes works within spec. I removed it, cleaned the OEM one, stuck it back in and it works.
