alright, what is the official name of the evap thing? i cant find it on autozone, oreilleys or rockauto's sites.......also, how do you know if your check valves for the vents are bad?, if you can blow thru them?
blow/suck or blow then flip it over and blow again. it'll take light air pressure to make the valve close.
if you have a bad one then it is more than likely the one on the side of the manifold (due to oil contamination, thanks to the pcv valve)
mine and my dads trucks both had a bad one on the side of the manifold. when i did a blow test they just stayed open.
