Blinker Wires
Old Sep 29, 2009 | 04:51 PM
95RAM360's Avatar
95RAM360
UPDATE-----
ok so i got a power tester, and i tested the wires i put in, both have power. then i checked the rear tail light wires, and found i have power for the running tail light, but cant get any power out of the blinking one.
Any help would be great
Old Sep 29, 2009 | 06:48 PM
zman17's Avatar
zman17
Retired Moderator - RIP
So did you actually read post #8? If you think all the wires,fuses,relays and flashers are good , then that's what to atleast try.
Old Sep 30, 2009 | 08:48 AM
95RAM360's Avatar
95RAM360
ok i tested all the wires going into the switch itself, and then the high beam flicker. and the Blue wires have no power going to them, and found that i have no power going from the flasher to the tail light fuse (there is a wire that goes from flasher to tail light fuse)
Old Sep 30, 2009 | 11:08 AM
AlabamaRam95's Avatar
AlabamaRam95
just becaue a relay clicks doesnt mean it works...
