Oil temp gauge reading hot
Old Sep 29, 2009 | 02:30 PM
flipture's Avatar
flipture
Ok here's the only pic I have of the truck right now. Unfortunately its blocked by my other two cars...
Old Sep 29, 2009 | 03:13 PM
DODGEPWR's Avatar
DODGEPWR
Originally Posted by flipture
Ok, so maybe its a 96 or 97. My mistake.
The gauge cluster looks like this if I recall correctly...
Yep, bottom right on that cluster is the coolant temp gauge..
And yours could also be a 94-95.. if im not mistaken.
Old Sep 29, 2009 | 03:53 PM
AlabamaRam95's Avatar
AlabamaRam95
mines a 95...looks just like that one.
Old Sep 29, 2009 | 03:54 PM
Augiedoggy's Avatar
Augiedoggy
thats a 96 style as well like mine....bottom left is fuel and bottom right is water/coolant temp..... I just changed my stat today and it looks like you'll likely be doing the same unless your really low on coolant or something else failed....mine was running hot and put a 180 dergree stat in and it runs 180 on the money now.... sweet!
Old Sep 29, 2009 | 04:55 PM
95RAM360's Avatar
95RAM360
mine runs at 195 about, and i have replaced the fan clutch water pump t-stat, timing cover gasket and the radiator was put inright before i bought it. So it could be either of those
Old Sep 29, 2009 | 05:06 PM
97r/tram's Avatar
97r/tram
When I first got mine, I had a similar problem. It ended up being calcium deposits in the radiator and they were blocking the coolant flow. I tried the 180 degree stat first, but it didn't fix it. I got the radiator for $150 wholesale from napa.
Old Sep 30, 2009 | 08:55 AM
flipture's Avatar
flipture
Checked coolant yesterday and I see none in resivour or radiator so that is likely my problem. I'm gonna fill them this afternoon and cruise around the neighborhood and see how it goes. I'll report back.
THanks again for all the quick help. I'm liking this forum already...
Old Sep 30, 2009 | 09:15 AM
DODGEPWR's Avatar
DODGEPWR
Cool, i hope for the best. Maybe its just a leak. And not a blown HG. Im sure youve checked your oil...I think you say you've already checked it. But, Make sure it doesnt look like coffee with da creamer and you should be good to go.
Maybe you didnt overheat it and cause any damage. Hope not!
Old Sep 30, 2009 | 11:08 AM
flipture's Avatar
flipture
Yeah I checked the oil that night. It was slightly dark but it looked/smelled ok.
I'm keeping my fingers crossed but I think I'm good . I'll let ya know...
Old Sep 30, 2009 | 11:18 AM
gobbell1's Avatar
gobbell1
bottom right is your coolant temp. It should hover around 200F +/-10F. If you gauge is pegging and your coolant levels are ok, I would replace the thermostat. It sounds like your t-stat is not opening and thus the coolant is staying in the radiator
