No horn, 97 1500
Old Sep 30, 2009 | 11:19 PM
sfs_ram's Avatar
sfs_ram
Default No horn, 97 1500
Bought a truck for my son to drive and the horn doesn't work (needs it to work to take driving test). Looked under left, front bumper and didn't find a horn but two connectors taped under the bumper.
Any idea what they are for? Trying to figure out how to upload pics.
Thanks!
Old Sep 30, 2009 | 11:29 PM
AlabamaRam95's Avatar
AlabamaRam95
get a photobucket account... www.photobucket.com its free
upload your photos to photobucket
then just click on the image code and copy and past.
Old Sep 30, 2009 | 11:58 PM
SpcD1500's Avatar
SpcD1500
sounds to me like someone removed the horn and left you wires hanging, we'll get a better idea once you figure the picture thing out (steps stated above)
Old Oct 1, 2009 | 01:08 AM
xray99's Avatar
xray99
I changed my horn not too long ago, as I recall, there was a black & blue connector that was not used for anything, then the horn.
You are talking drivers side, right ?
Should be visible laying on your back under the bumper.
Not sure why someone would just take it out, those things generally do not come out unless you unbolt them.
Who knows, but take a look at the horn connector and see if you can find something that matches up with it.
Junkyard might be the best, auto store horns usually require some modification to connect.
Old Oct 1, 2009 | 01:22 AM
dakotas ram's Avatar
dakotas ram
horn button may have been stuck and they removed the horn....or a bad relay stuck closed......but why remove and not just unplug? ii also think that i read somewhere that the horn is in a dif spot on some trucks, but mine is drivers side
Old Oct 1, 2009 | 07:32 AM
95RAM360's Avatar
95RAM360
mines on the drivers side as well, and my mount for it broke so its hanging down, maybe yours was hanging as well, and the horn came unclipped and fell?
and i have heard of those with the horn stuck, but usually they take the fuse out, and not the horn.
Old Oct 1, 2009 | 09:03 AM
sfs_ram's Avatar
sfs_ram
Default pic of the connectors
Was able to upload a picture of the connectors. Any ideas?
Old Oct 1, 2009 | 09:10 AM
Sheriff420's Avatar
Sheriff420
if you get the freeway blaster horns (high and low tone) then all you have to do as far as modification is cut the original wires and crimp on two connectors for each horn.
those look like my stock horn plugs. where are you at? i still have my stock horns and don't have any use for them.
Old Oct 1, 2009 | 09:12 AM
95RAM360's Avatar
95RAM360
exacally i just went to AZ, and i looked for a new one for mine. and all you have to do is splice the wires....very easy
Old Oct 1, 2009 | 09:54 AM
Sheriff420's Avatar
Sheriff420
i think the freeway blaster horns are about 15$ each at oreilleys and advance.
