HELP! ball joints
Old Oct 4, 2009 | 08:17 AM
Mojo1967's Avatar
Mojo1967
Exclamation HELP! ball joints
I am trying to replace ball joints (upper and lower) on a 1999 dodge 1500 4wd. issue is I cant get the lower to relese from the knuckle so i can get to it with the ball joint press. I have the hub, shaft, and tie rod end out...upper is free but lower wont go. i tried to press it out to no avail...I already distroyed one pickle fork too! Is there some miracle tool or procedure that might help? i need help now as my truck is curbside half taken apart at the moment!
Old Oct 4, 2009 | 08:39 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Have you been using some quality penetrating oil? It's just rusted on the stud obviously but, it sounds like you just need a BFH and some patience. Heat will help too if you have access to a torch.
Old Oct 4, 2009 | 08:49 AM
Sheriff420's Avatar
Sheriff420
heat and cold together. if you can't find some crc freeze off then grab a can of canned air.
heat the knuckle and freeze the ball joint then immediately hit the ball joint with the hammer. if you have to use canned air then you will have to have the can upside down for it to actually freeze the ball joint.
you can get a propane torch at k mart or walmart pretty cheap also. i'm talking about the kind that goes on the end of one of those little bottles of propane.
Old Oct 4, 2009 | 08:55 AM
Mojo1967's Avatar
Mojo1967
well I have a torch and a BFH but Im fresh out of patience...thanks Ill give it a shot...is it possible to cook the knuckle too much?
Old Oct 4, 2009 | 08:56 AM
Mojo1967's Avatar
Mojo1967
also...is there a better or best puller for the job available....maybe one specifically for the truck?
Old Oct 4, 2009 | 09:05 AM
Sheriff420's Avatar
Sheriff420
yes you can give it too much heat. don't make it glow.
and go to a parts store and get the loan a tool ball joint removal kit
http://shop.advanceautoparts.com/web..._T|GRP2083____
Old Oct 9, 2009 | 05:04 PM
Mojo1967's Avatar
Mojo1967
done...thanks folks
seals are next
