Is this wild vents?
Old Oct 4, 2009 | 08:53 PM
Trey318's Avatar
Trey318
Default Is this wild vents?
Well, in this last week, my A/C will only blow through my defroster vents. Regardless of RPM or mode on the switch, the air only blows through my defroster vents. Typically, with the Wild Vents the A/C blows from the defroster vents when the engine is at a higher rpm. Well, I had that issue for a while, and then all of a sudden, I noticed it stopped blowing out of the normal vents and only went through the defroster. So what I'm wondering is if it really is the wild vents or is something else.
Any help appreciated. I like the windows down, but it sucks when its rainy.
Old Oct 4, 2009 | 09:21 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Seems like like you never corrected the problem when it first came up, so I would say YES. But you need to eliminate it as a cause anyway.
Old Oct 4, 2009 | 09:51 PM
Trey318's Avatar
Trey318
Alright. I'll write the part numbers down so my dad can get the check valves. He went to the dealer the other day and they had the 'wtf' look on their faces.
Old Oct 4, 2009 | 09:58 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Sounds about right.
Old Oct 5, 2009 | 07:59 AM
zman17's Avatar
zman17
Of course you need to check the hoses everywhere too.
Old Oct 5, 2009 | 07:42 PM
Trey318's Avatar
Trey318
Is there a way to verify the check valves? My dad thinks Im full of **** for some reason
Old Oct 5, 2009 | 08:25 PM
Trey318's Avatar
Trey318
Well it turns out one of my door actuator diaphragms are leaking. Plus my check valves are shot. If someone could hook me up with some parts numbers for the valve that would be great
Old Oct 8, 2009 | 07:27 PM
Trey318's Avatar
Trey318
Got the actuator replaced, and it works great again. Only one of the check valves is bad, so overall I'm pretty happy.
Old Oct 8, 2009 | 07:46 PM
zman17's Avatar
zman17
Check out this thread, I think he has an extra check valve. https://dodgeforum.com/forum/2nd-gen...-question.html
Old Oct 8, 2009 | 09:44 PM
004x41500's Avatar
004x41500
since were talking about it, anyone have an idea why my heat doesnt work? the hoses are all hooked up under the hood, but when i turn the **** to hot nothing happens...and it stays cold.
