got a base dyno test today 5.2L
Old Oct 8, 2009 | 01:14 PM
  #21
xskylinedx's Avatar
xskylinedx
Originally Posted by AlabamaRam95
ive been running a 180 tstat since day one. most of the heads that cracked were either high mileage or over heated/long term uses. also the majority of "prone" cases broke at cylinder 7, so if you do want to work stock heads you just have to pay special attention to that cylinder and use the correct torque settings when putting it back on.
i still dont buy in to the heads being prone to cracking. plenum gaskets are prone to blowing out. cracked mag heads are isolated cases.
Guess I'll have to agree to disagree with you. Stock heads crack with the possible exception
of stock r/t heads. My guess is that they brake at cylinder 7 due to the lean condition found
there.
Old Oct 8, 2009 | 01:18 PM
  #22
xskylinedx's Avatar
xskylinedx
Originally Posted by DODGEPWR
Wow, that horsepower sure is impressive!!! NOT! LOL
Atleast torque wasnt that bad. What was done to the engine at the time of the dyno? Anything?
Its a 5.2 and I would bet it runs harder than your little stocker. Green is not a good color for you ;-)
Old Oct 8, 2009 | 01:24 PM
  #23
DODGEPWR's Avatar
DODGEPWR
im know its not much HP compared to the 1000HP 5.2L you have, but maybe one day i will gain enough knowledge to make it happen. NOT! LOL
as far as engine mods go... not much really. CAI, ignition, exhaust, some drivetrain mods. nothing major though.
Yea, sure...Like i said my 5.2 makes more power than yours. wow. Learn to read dude. I wasnt saying that to say your 5.2 is weak and mine is better. It was just a comment on how s***y the stock HP #'s were for the 5.2 in general. But anyway, Ive been wanting to get a 14/3 round air cleaner for my truck and thought you might have had one on yours. Ive had one in my hand at the autoparts several times, walking to the counter with it. But ive always went and put it back on the shelf. For one reason only tho..Ive heard people say you loose low end torque.(yes here on DF) And i do not want to loose any low end torque, cause after all it is a truck. I wish someone would do a dyno of a before and after the 14:3 air cleaner. Would be pretty cool to know what gains you get and if you loose low end torque. How much do they charge you to dyno your truck where you went? Here i think it was like $75 a pull or somthing. (or maybe it was $75 for 3 pulls at dyno day) I dont know for sure. Id have to check again. Its been a loooong time since i checked. I may dyno mine and do some before/after pulls next dyno day....
Same for you...^^READ! And BTW, you make no sense....
Old Oct 8, 2009 | 03:24 PM
  #24
AlabamaRam95's Avatar
AlabamaRam95
comon...thick skin guys. if you are gonna drive a dodge...you gotta have thick skin. especially in the "CHEVY is a religion" part of the world i live in.
as far as gains for the CAI, i really dont know. ive never been a real stickler for the hole 4-5 hp or 3-5 ftlb gains. HP changes from day to day depending on the conditions anyway. (kind of like my weight...250 260 255...who cares)
its the 40 50 60 gains i wanna see.
i didnt pay anything for the dyno. i own a retail store and have lots of customer contacts. theres a speed shop accross town here that ive been doing some work for and he did the dyno for me. jean is also the one thats doing my headwork this weekend.
  #25
Augiedoggy's Avatar
Augiedoggy
(he means green with envy) I got it.... and when I read your first post I couldnt tell if you were being sarcastic either so.....maybe it was just a little miscommunication on both ends....
I doubt the air filter will really show any noticable gains on our engines......maybe if you had the 52mm throttlebody mod and a high flow exhaust you might see something but if that were the case a properly designed and installed CAI would make more sense than a 14x3 sucking in all that hotair...
Old Oct 8, 2009 | 03:37 PM
  #26
AlabamaRam95
ROFLMFAO!!!!!!!!!!
you guys kill me...the hostility....whew.
goosfraba goosfraba goosfraba
Old Oct 8, 2009 | 03:48 PM
  #27
DODGEPWR's Avatar
DODGEPWR
ROFLMFAO!!!!!!!!!!
Goosfraba LMAO. Thats off of that there movie anger management right?
Old Oct 8, 2009 | 04:06 PM
  #28
xskylinedx's Avatar
xskylinedx
I did read it, maybe you need to learn how to write better. If you meant nothing than all is
well, just standing up for another dodger. If what I said doesn't make sense, think about it
for a bit ;-)
Old Oct 8, 2009 | 04:08 PM
  #29
AlabamaRam95
WHERE DID YOU GET THAT S**T!!!
NOT FROM ANGER MANAGEMENT !!!!!!!!!!!!!!!
i came up with that... and they took it from me.
g o o s f r a b a g o o s f r a b a
Old Oct 8, 2009 | 04:09 PM
  #30
xskylinedx's Avatar
xskylinedx
Have you thought about a 408 or 426 build?
