Seepy Rear End
Old Oct 7, 2009 | 03:15 PM
el_oso's Avatar
el_oso
Question Seepy Rear End
I was looking at changing out the differential oil and, while I was at it, surfacing and painting the punkin cover. However, the rubber plug does and has always seeped making things look crappy. My friend has a Cherokee that does the same thing. Has anyone heard of a hard bolt plug swap out for this?
Thanks.
Old Oct 7, 2009 | 03:27 PM
dakotas ram's Avatar
dakotas ram
im sure you can weld a bung on there and put aplug in
Old Oct 7, 2009 | 06:22 PM
dodgeboy1979's Avatar
dodgeboy1979
I thought most had a metal plug.... mine does. I think the rubber plug comes from the
@$$holes that strip your metal one out at the quick lube bays lol. Should be able to retap the punkin and put in a metal plug when you got it off.
Old Oct 7, 2009 | 07:56 PM
charlie1935's Avatar
charlie1935
My 87 came from the factory with a rubber plug.
I don't know about other manufacturers but Chrysler has used them well over 20 years.
Old Oct 7, 2009 | 09:17 PM
dhvaughan's Avatar
dhvaughan
all the 9.25's have a rubber plug. you just need to buy a new plug, probably from the dealer, probably for $4 or $5. mine doesn't leak. you might try one from autozone or somewhere, just make sure the size and lip is right. if you find a cheapo that works, post it.
Old Oct 7, 2009 | 09:20 PM
dodge15004x45.9's Avatar
dodge15004x45.9
My dana is metal. Are you sure about that now I want to go under the truck and look.
Old Oct 7, 2009 | 10:37 PM
dhvaughan's Avatar
dhvaughan
dana 44/60/70/80 has a threaded pipe plug.
chrysler 8.25/9.25 have a .05 rubber plug. nothing but the best. haha
improved version.
http://stores.hi-potek.com/-strse-2/...ar-/Detail.bok
same thing more money...
http://www.yourcovers.com/diffcover_9518.php
Old Oct 7, 2009 | 10:50 PM
dodge15004x45.9
Hell just go out and buy this.
http://www.mag-hytec.com/store/index...31efbaf03241bd
Front.
Old Oct 7, 2009 | 11:22 PM
dhvaughan's Avatar
dhvaughan
i just can't bring myself to spend $500 on diff covers.
i do like that sheet metal rear cover for $75. i wish they had a similar cheap d44.
so here's a kit with drain/fill for the rear, and drain for the front.
seems kind of expensive at $42 just for the bungs and plugs.
http://stores.hi-potek.com/-strse-64...ain/Detail.bok
is there any reason why you couldn't just drill a hole and weld a nut on the outside of the cover. put a little rtv on the threads to prevent leaks.
you'd want a magnetic drain bolt.
i wonder if you could buy one?
i wonder if you could magnetize a regular bolt? hmm, we have some magnetizers at work. i'll have to talk to somebody that knows.
Old Oct 7, 2009 | 11:52 PM
dodge15004x45.9
When i do my gears I'm buying one fore the rear.
